my drivers side window takes a long time to go up and it can not shut the window all the way when the door is closed now (new weather seal) is this just a old tired motor? also how difficult is it to change the motor do you need to remove regulator too?
Yep - need new motor - do both sides and be done. Do a search for "bogus" and you'll see a tread about doing it the easy way without removing regulator.
after 20+ yrs. they do get tired . will they work as fast as new cars with new motors , no . anyway good luck .
valicswarrior
close
- Join DateOct 2010
- LocationVirginia Beach, VA
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- Car1985 Firebird S/E
- EngineSBC 350, mild cam Vortec heads
- TransmissionRebuilt 700R4 vette servo+shift kit
- Axle/Gears3.73
- Liked:0 Times in 0 Posts
easy way to do it is leave the rivets holding the regulator alone and just drill holes in the door since your gonna cover it with the panel anyway and drill out the rivets that hold the motor to the regulator if you remove the regulator it is a lot of extra work and oh yeah put something in place to hold the window in place like some c clamps on the tracks or something there is a thread with some pics if you cant figure it out but its pretty easy once you look at it to see the way of doing it
JamesC
close
The motor may well be tired. However, in advance of replacement, I'd try cleaning and lubing the moving parts. You may be surprised. If the above fails to work, you've lost nothing and have removed parts required to replace the motor.
JamesC
JamesC
Quote:
JamesC
Originally Posted by JamesC
The motor may well be tired. However, in advance of replacement, I'd try cleaning and lubing the moving parts. You may be surprised. If the above fails to work, you've lost nothing and have removed parts required to replace the motor.JamesC
+1 on this idea. Made a very noticeable difference on my driver side window.....now if only I had some time to do the pass side.
Former Sponsor
Quote:
Firebird Window Motor
yup, those are competitive prices with the free shipping. I just picked up one yesterday and Adv Auto matched price for me at $29.99. I paid sales tax so your price is right there.Originally Posted by 1ATony
I have new window motors here that aren't to much money.Firebird Window Motor
But I get the "daily double". The regulator is broken and i bought a used one on line. I get to repalce the window, regulator and motor.........fun fun
Oh, if you want tips on doing the motor, just look up for a 4th gen. I think shobox has it on his site as well. i had to replace them in my 4th gen too.
i had the same problem in my last car .. it was the window switch .. it had got corroded and was limiting the voltage to the motor.. check that aswell
articwhiteZ
close
i had a window replaced..after they did the work.. the window was alot slower.. and leaked.. had to take it back.. a few times till they got it right.
ran fine after that..
safety auto glass... not so hot
