Different Arm Rests
Old Feb 26, 2011 | 06:22 PM
marmieej's Avatar
Car: 1988 IROC Camaro
Transmission: 700R
Different Arm Rests
There seems to be different type armrests specifically where the upper bolt goes through and mounts the rest to the physical door. Some arm rests allow for a plastic covering (or beauty trim) that provides a better look. Other pieces seem to have the same vinyl/plastic that the door rest is made out of go all the way back.
I was going to switch out my door rests in my Camaro. The current ones I had used the plastic beauty trim ring but the new ones I bought cannot have the trim ring put on due to the 2nd scenario above I described.
Can someone shed some light on this for me? I installed the new armrests and it looks tacky at the top without the beauty trim plastic piece. Is there a different piece I need to get instead?
Old Feb 26, 2011 | 06:26 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Different Arm Rests
As you said, some are different. Some are totally smooth, some have indents all the way on the facing, some have the beauty ring you describe, some don't. Just have to get the kind you like.
no green
Jan 9, 2016 09:22 PM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
gord327
Oct 3, 2015 01:25 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
