power window switches...
Old Mar 3, 2011 | 09:02 PM
UsedandAbused's Avatar
Car: '92 Camaro RS
Engine: 3.1
I looked thru the entire forum all seven pages for pictures of the power window switches. Does anybody have any?
I picke up some used Irock doors for a good price, and since i have to change out the window reg on my passenger side, i thought about upgrading to power windows...alot of work I know.. they are going into a 92 RS all manual.
but i need to see a picture of what the switches look like so i can mimick them in the add on.
thanks in advance...
Old Mar 4, 2011 | 09:25 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: power window switches...
They look like:
http://cgi.ebay.com/ebaymotors/82-89...item588ca6d1d3
They are located in the center console top (not in the door) - your non-power window console will have rectangle areas marked on the underside to cut out I believe - between the shifter and the console lid.
Old Mar 5, 2011 | 12:01 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
You'll notice that eBay ad lists them (correctly) as being correct through model year 89. In 90 the print on the switch changed to yellow. That switch will work fine for your application, just letting you know of the original difference.
Lon
Old Mar 5, 2011 | 12:56 AM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Best price I've seen on these
http://www.classicindustries.com/con...=1&sortOrder=1
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
