Custom speaker covers???
Old Mar 9, 2011 | 04:54 PM
Part Timer's Avatar
I have a set of speakers and they do not fit under the stock sailpanels. Have any of you fabed up some custom ones and if you ahve please post pictures.
Thanks,
Bob
Old Mar 9, 2011 | 07:51 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Re: Custom speaker covers???
Get speakers that fit the opening!
Old Mar 9, 2011 | 08:07 PM
Part Timer's Avatar
That would be too easy.
Old Mar 9, 2011 | 09:50 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
I went the cheap-o route and cut out the backing to the sail panel where the oval for the speaker was. So when they were on the speakers just barely pushed against the fabric.
Old Mar 9, 2011 | 10:57 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I pretty much did the same thing to cover a set of 8" woofers in the sail panels. I still need to remove the fabric so I can cover the board with resin and stiffen it up, pretty flimsy as is. Currently, the very bottom of the woofer slightly pushes against the fabric.
Old Mar 10, 2011 | 12:43 AM
valicswarrior's Avatar
Car: 1985 Firebird S/E
Engine: SBC 350, mild cam Vortec heads
Transmission: Rebuilt 700R4 vette servo+shift kit
you could also use the speaker grate that usually comes with them and cut ur sails and attack the grate to the sail would give you your clearance and make it look a little different before cutting anything though stick a speaker grate on the sail and see what it loks like
Old Mar 10, 2011 | 04:40 AM
Mark_Hardware's Avatar
Car: 1991 Camaro Convertible
Engine: Hellifi-no special
Pick up some of these;
http://www.google.com/#sclient=psy&h...28c751aca5f830
Then you can also use whatever speaker cover came with the speakers.
Its what I use.
Hotrodboba400
Dec 10, 2019 07:07 PM
Nick McCardle
Sep 10, 2015 08:36 PM
84 TA NV
Sep 6, 2015 08:02 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
