removing/intalling windows
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Hey sorry guys i tried the search engine in the body and interior sections and i keep getting power window threads and window adjustment threads
and nothing directly towards removing or installing windows in the tech articles.
i'm trying to find a step by step process after everything is out of the way to remove the windows and install
i already have my door apart. where does the window need to be for easiest way to remove?
half way or all the way up to slide it on and off the tracks?
Re: removing/intalling windows
I just did it
you need a 2-3 foot pry bar and a helper for the removal (seriously)
put window halfway of your motor actually works
my regulator was toast as was the motor so I drilled out both so removal was much easier. I had 2 new windows I bought a while ago so it was as good of time as any to replace the glass.
You're going to have to unbolt the channels that the regulator rolls in and remove the guide that the window roller rolls on
the rollers for the regulator get removed to the left (rear of car direction) because there is a stopo if you try to push them toward the front
Once you get the tracks disconnected you need to work the wiondo up and the pry bar is for prying the door panel outward for that final "pop"
Car: 1983 camaro
Engine: 350 soon to be 355
did search and it was 2nd thing to pop up, this is what i used.
https://www.thirdgen.org/forums/faq-...oor-glass.html
Axle/Gears: no idea
thanks guys
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Wow a pry bar??? I leave them all the way up and remove the front triangle piece and mirrior and they come out pretty easy sliding them just forward
it sounds scarey but it's not.
Car: 89 IROC
Ah a new way to do it as like I said when I take out those 2 pieces and gap is wide enought that it will slip out with out one. Still good to know incase the windows arnt up.
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
where can I get a new window regulator for an 1983 trans am?
I need the passenger side regulator, the window motor is new. is the drivers side you have new ?
