rear hatch
Old Apr 11, 2011 | 01:10 AM
musclecars90's Avatar
Car: 1986 Iroc Camaro
Engine: 305 5.0L
Transmission: 700 R4
rear hatch
I give up on the rear hatch. is there a way to keep the motor in the down position but have the locking mechanism still work, so it can still be open and closed without the motor pulling it down
Old Apr 11, 2011 | 05:37 AM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
Re: rear hatch
You could unplug it, but the light won't work if you do that. You could hold down the lever that moves it then when it gets to where you want it to be just unplug it. I wouldn't though.
What's wrong with yours?
Old Apr 11, 2011 | 11:02 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: rear hatch
I tried that once - I drilled through the slide, and inserted bolts so that the slide wouldn't move, and disconnected power to the motor. The hatch squeeked really bad, no matter how I adjusted the stops and the rubber bumpers - drove me crazy! 2 weeks later I just fixed the motor to work correctly.
www.top-downsolutions.com has all the parts needed to restore a motor to operate correctly. Lon also has a write-up here about the operation of the motors, how to repair, and everything. It was in pdf form, and was referenced a few days ago, so it should appear in a recent post - do a search for hatch and look through all the threads for the last 4 days, I know it's been less than 4 days since I read it.
Old Apr 12, 2011 | 12:15 AM
Engine: 305 5.0L
Re: rear hatch
my motor keeps on pulling even when the stops are as low as it can go. And a few days later it stopped pulling and a few days after that it keeps pulling again.
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
