Horn going off with change on steering wheel
Old Apr 19, 2011 | 01:07 PM
podiatra's Avatar
Car: 1986 Camaro IROC-Z
Engine: 350 swap
Transmission: manual
I have 1991 Firebird which have a non- air bag steering wheel working fine. I have remove it so i can place the original. Now when i connected the original steering wheel, and place the air bag the horn goes off....non-stop. I ma thinking that the problem has to be in the steering whell since the horn was working fine with the other steering.
Any suggestion what or where may be the problem at?
Thanks in advanced.
Old Apr 19, 2011 | 05:30 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: 4L80e
Axle/Gears: C5 IRS
Re: Horn going off with change on steering wheel
The horn wire only needs to be grounded to turn on the horn. Somewhere the wire is touching when you put on your new wheel. Most have a plastic sleeve to keep this from touching
Old Apr 19, 2011 | 08:04 PM
podiatra's Avatar
Engine: 350 swap
Thanks for the info. The plastic sleeve you refer to is around the horn wire? It seems that the horn goes off when the base (metal) of the steering wheel touches the shaft.
Frozer!!!
Jan 19, 2024 04:55 PM
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
