instrument cluster project - need some help
Old Jun 27, 2011 | 01:17 PM
sabresfan's Avatar
Car: Looking for a new thirdgen
Engine: hopefully a 5.7L 350
ok so today i went about taking apart my cluster to begin my project of swaping out the cluster lights for brighter led's. when i finally got the cluster out i was really stupid and began pulling out the light sockets at random and didnt bother to remember where any of them specifically went or what color sockets went where. I have an 86 iroc and all of the threads about led swaps tell me that i only need 11 of the led's to make the swap specifically for the instrument cluster lights. i couldn't help but notice that there are a lot more than 11 sockets. i realize that there are sockets for the turn signal flashers, hi beams, and the warning lights but even after subtracting those there are still more than 11 sockets unspoken for. can anyone help me out here? maybe a picture of the back of the cluster or a link to something that might help me out.
Old Jun 27, 2011 | 08:58 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: instrument cluster project - need some help
There is a total of 22 locations for light sockets. 11 for gauge lighting, 2 for directional indicators, one for the high beam indicator, and 8 across the bottom for "idiot" lights. Of the 8 across the bottom, not all locations are used, you'll need to check your gauge bezel (the black plastic piece) and see which ones have a labeled lens (BRAKE, CHECK ENGINE, etc) and what color the lens is.
Old Jun 27, 2011 | 11:12 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
fyi theres a thread or tech article with a picture of the rear of the gauge cluster, and some arrows pointing to which ones you should swap out and which ones you should leave, should help, don't recall if it was one of the threads or the tech article, but its around here somewhere.
Old Jun 28, 2011 | 12:01 AM
Al Hasse's Avatar
It's in a tech article. I found it here...
https://www.thirdgen.org/leddash
It also explains how to build your own LED lights to work in the sockets. Easier to buy them preassembled from a site like www.superbrightleds.com or www.v-leds.com
Old Jul 4, 2011 | 10:27 PM
Joecat's Avatar
Engine: 2.8L V6
Transmission: 7004r
While that article is specific to the IROC dash, with a bit of trial and error I should be able to apply those same principles to my Firebird dash, right?
Old Jul 4, 2011 | 11:25 PM
Engine: 3.8, 3.4
should yes, if it uses normal light sockets and what not.
mattcanty
Oct 12, 2015 11:08 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
