Footwell lighting etc
Old Aug 1, 2011 | 09:32 PM
  #51
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Re: Footwell lighting etc
Originally Posted by 80schild
It's fairly simple, just remove the dash pad and the plastic shroud around gauges, then you'll see 6 (or maybe 8) screws that hold in the cluster. Just tilt it forward and pull it out. I did have to lower my column a bit to make it easier, but I already had my plastics off, so it was no big deal.
I replaced my old dim 168's with fresh new 194's, it made a BIG difference. If I ever go LED in there I'll probably go with red, to look like newer Pontiacs.
Also have to disconnect the speedo cable if its not VSS which is a major pita, I can't remember if 89 was the last year of cable driven, or the first year of vss though.
Old Aug 1, 2011 | 10:41 PM
  #52
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Firebirds went electronic in '86 except a few base models with the dummy lights.
Old Aug 1, 2011 | 11:15 PM
  #53
bbgunn11's Avatar
Car: 1991 RS
Engine: 3.1L
Luckily my 91 has no cables..
Old Aug 1, 2011 | 11:26 PM
  #54
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Originally Posted by Mike92Firebird
All done. Bought them all online. For my footwell lights they're a 914 bulb with three forward facing LEDs and claim to be the brightest avaliable to consumers for 914's. I dont't doubt this. I have never seen so much light from such a small bulb. I've got a panel LED with a festoon adapter for my dome. And I'm using forward facing LEDs for the mirror lights. All a nice 6000K
These pictures are a terrible representation, I'll try taking some tonight.
Mike92Firebird, If you dont mind, what is the part numbers for your dome light and the rear view mirror lights (map light). I ordered a dome light like the one below and I must say, I was disapointed. It wasnt bright like how your picture portrays. Thanks.
Old Aug 2, 2011 | 01:09 AM
  #55
Mike92Firebird's Avatar
Car: 89 GTA
Engine: 5.7 TPI L98
Transmission: 700R4 w/ Stage 2 shift kit & stall
This is what the floor lights are - http://www.v-leds.com/Interior-LED-B...87987-1-2.html
They are dangerously bright. Can't even explain. 194 type bulb
This is the mirror lights - http://www.v-leds.com/Exterior-LED-B...81133-1-2.html
had to go with a slightly smaller bulb cuz the space in the mirror is extremely small. Also very bright.
Last but not least this is my dome light - http://item.mobileweb.ebay.com/viewi...d=571666056014
Old Aug 2, 2011 | 10:53 PM
  #56
Car: 89 GTA
Engine: 5.7 TPI L98
More attempts at showing the light
Old Aug 2, 2011 | 11:41 PM
  #57
Look what I bought earlier...
Cant even beat a $3.29 LED panel and connection set with a cheap pretty penney. Coming from Hong Kong with free shipping!!!!! But we'll see how long it takes to arrive.
Old Aug 3, 2011 | 12:44 AM
  #58
Car: 89 GTA
Engine: 5.7 TPI L98
That's an amazing deal! Shipping should take a week in a half or so. Should fill the dome light quite nicely.
Old Aug 3, 2011 | 01:28 AM
  #59
bbgunn11's Avatar
Car: 1991 RS
Engine: 3.1L
I love the way the dome looks, I figured since my stock bulb was bright enough a brighter bulb should do the job for me. If not, Im definitely going to order one of those.
Old Aug 3, 2011 | 01:39 AM
  #60
Car: 89 GTA
Engine: 5.7 TPI L98
Maybe I'll take a close-up of the dome tomorrow. It really does give off a TON of light.
Old Aug 8, 2011 | 03:01 PM
  #61
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Well both of my footwell lights have quit working, the pass side went about ten seconds sooner than the driver side. This happened while starting the car with the door open, and when I took the driver side one out it did feel a little hot.
I've got two more on the way, but if it happens again I'll be going back to 194's.
Old Aug 11, 2011 | 04:53 PM
  #62
bbgunn11's Avatar
Car: 1991 RS
Engine: 3.1L
My lights came, looking pretty good.
http://imgur.com/a/DFVVN
Last edited by bbgunn11; Aug 11, 2011 at 05:39 PM. Reason: posted link to pictures.
Old Aug 13, 2011 | 01:32 AM
  #63
I just installed my 36 LED board into my dome light. Let me tell you. Have you heard the saying, "the dear froze in my headlights"?
Thats how I felt when the damn board lit up. That crap is BRIGHT!!!!! When it lit up, I froze for a split second because it was so bright. While stunned, in a split second, I contemplated on pulling the board or drive on and continue the install while being horrifically and temporarily blind. But after the installation of the map lights and the dome light, I must say, IT IS NIIIIIICE. It is a must to have this cheap mod. Gotta love it!
Old Aug 13, 2011 | 02:05 AM
  #64
bbgunn11's Avatar
Car: 1991 RS
Engine: 3.1L
My dome looks pretty good, definitely bright enough.
Old Aug 18, 2011 | 05:52 PM
  #65
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Well I think I'm done with the LED's. My 36-led panel stopped working after one week. I was working on my radio and my door was open 5 minutes max, looked up and no dome light. Is it just me, or are these things junk.
Old Aug 18, 2011 | 05:59 PM
  #66
I think it may be bad luck. I had my dome light on for about 6 hours during a club meeting and she is still running top notch.
Old Aug 18, 2011 | 06:22 PM
  #67
bbgunn11's Avatar
Car: 1991 RS
Engine: 3.1L
I had my dome on for about an hour and it is still going strong
Old Aug 18, 2011 | 09:45 PM
  #68
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Apparently the dome LED's will work if I push the button on the overhead console, but not when I open the doors or use the headlight dial. The footwell lights still work normally.
I'm even more confused now.
Old Aug 19, 2011 | 01:21 AM
  #69
Hmm. Interesting.
Old Aug 24, 2011 | 01:46 AM
  #70
Car: 89 GTA
Engine: 5.7 TPI L98
LEDs are strange and in most cases you get what you pay for. Sometimes it's worth shelling out the few extra bucks to ensure they'll work properly and for longer. Since I bought sorta pricey ones, I still haven't had any problems with mine yet. It can be a hit or miss type thing. Just gotta check all leads.
Old Aug 28, 2011 | 03:39 PM
  #71
bbgunn11's Avatar
Car: 1991 RS
Engine: 3.1L
I installed my dash LED's, ordered a new dome light and changed my heater light also. Im hopefully installing the foot well lights sometime this week and ill probably change the rear view mirror lights too. The dash isn't as bright as i'd like but at night it looks pretty good. The dome was bright enough but I want it to be extremely bright so i ordered a panel.
Old Dec 14, 2011 | 10:42 AM
  #72
camaro1122's Avatar
Car: 1991 Camaro Z28
Engine: 5.0 LB9 TPI
Axle/Gears: 2.73 posi drum
Are these footwell lights stock or after market? And are they on camaros or just firebirds/trans am?
Old Dec 14, 2011 | 11:29 AM
  #73
Car: 89 GTA
Engine: 5.7 TPI L98
As far as what I did on mine, I just used the stock locations that come on all 82-92 fbodies and swapped out the crappy dim incandescent bulbs for brighter, better looking LEDs.
Old Dec 14, 2011 | 01:40 PM
  #74
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Sorry to be more specific to my question, are these footwell lights on all 82-92 f bodies? I never seen one in my 91 camaro.
Old Dec 14, 2011 | 01:48 PM
  #75
On my 86, it had them as OEM. But is special because I have the Boss kick panel speakers.
Old Dec 14, 2011 | 02:24 PM
  #76
Car: 89 GTA
Engine: 5.7 TPI L98
Basically on all 82-92's that I've seen, Camaros and birds, there is a small light above the drivers feet as well as above the passengers feet. It's covered by a small yellow lens on each side. All I did was replace these factory bulbs with LEDs
Old Dec 14, 2011 | 03:31 PM
  #77
Yup. True. But the 3rd gens with the Bose kickpanels had the little bulb holder because of the bulkyness of the passenger side kickpanel. It covers the entire hole that houses the bulb on the hush panel.
Old Dec 14, 2011 | 04:50 PM
  #78
camaro1122's Avatar
Engine: 5.0 LB9 TPI
Where is that light located? The only one ive seen is (for camaros at least) under the center vents.
Old Dec 14, 2011 | 05:05 PM
  #79
For my 86 IROC, there is one simple with a recess cut out for the light bulb house plug (insert and turn plug to lock in place type). Same thin on the passenger side bush panel. A dimple with the cut out like how I just described. But also, on the Bose kickpanels, there is 2 little holes drilled in the upper corners where there is used be the light holders.
Old Dec 15, 2011 | 09:28 AM
  #80
chevypower91's Avatar
Engine: 305 cid
Transmission: 5 speed
Axle/Gears: Posi/3:42
Does anyone know if a '91 Z would have footwell lighting on the passenger side? If so, were is it located exactly?
I do see one on the driver's side, but not the passenger.
Old Apr 11, 2012 | 12:51 AM
  #81
cha_chard's Avatar
Car: 89 Camaro RS
Engine: 2.8L V6 MPFI
Transmission: 5Speed
has anybody rigged the stock foot well lighting to turn on when the headlights do? so i don't have to have my dome light on when im driving at night, especially cuz its brighter
thanks
TrevinE
Sep 14, 2015 03:20 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
