Center console removal
Old Jul 25, 2011 | 08:26 PM
therobot's Avatar
Car: 1991 Camaro RS
Hey guys, ive tried searching the forums but I haven't found an answer to my problem. I'm getting ready to install new carpet in my '91 Camaro and have all the interior removed other than the center console. I have already removed the shifter plate that's connected to the ash tray...but I'm unable to remove the bigger plastic piece (what the glove box is attached to). I can't get it over the ebrake to save my life!!! Heres a pic of the piece I'm talking abt :
Please give me any tips! I don't want to break it! Thanks
Old Jul 25, 2011 | 08:46 PM
891-92camaro's Avatar
Car: 92 camaro 25th anniversery
Engine: 350 TBI
Transmission: 700 R4
Axle/Gears: 3.73 9 bolt
Re: Center console removal
should be bolts in the bottom of the center console/glove box and i believe by the shifter and two up by the heater/ac control then it should come out amd slide rite over the e brake handle
Old Jul 25, 2011 | 08:47 PM
DD9TransAmGTA's Avatar
Car: 1987 TA GTA, 1987 IROC 1988 Formula
Engine: 350 tpi/305 tpi/350 tbi
Transmission: All have 700r4's
Axle/Gears: 10 bolt with 3:73's
i recently took mine out, i'm pretty sure you need to take out the radio bezel
Old Jul 25, 2011 | 08:48 PM
aqualordx93's Avatar
Car: 1986 Camaro Iroc Z
Engine: V8 305 TPI
You need to remove your Head unit and un bolt the AC controls.
The whole center console is are 2 pices.
1 is the plastic, which has the glove box, ash tray and shifter area.
2 is the carpeted area which has some bolts that need un fastening.
And VWALA!!
When removing your carpet it will be difficult to get the piece between the 2 seats up by where the head unit and AC part is, took me a few tries (should be taped together or something)
I kinda just yanked it out. But be carefull.
It will be fun putting that area back in...
Good Luck!!
Old Jul 25, 2011 | 08:49 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
You have to man handle the Ebrake to an almost completely straight up/down position. Also, the center console lide must be opened straight up as well (the lid spring gets caught on the console bottom if not opened.
Old Jul 25, 2011 | 08:55 PM
therobot's Avatar
Car: 1991 Camaro RS
Thanks for the quick replies!!
Old Jul 26, 2011 | 04:22 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
I will be taking out my console as well, but I have a bird. Are the steps to taking it out similar? I ask because the bird has a console, and the radio pod is separate.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Night rider327
Sep 2, 2015 04:17 AM
DonW
Aug 24, 2015 08:24 PM
Firebird sweden
Aug 16, 2015 05:02 PM
