speedo swap
Old Aug 18, 2011 | 06:26 PM
titan7's Avatar
Car: 1985 camaro
Axle/Gears: 3:42
speedo swap
I have a 1985 camaro,I've swapped out the old motor for an Lt1/4L60e from a 1996 camaro,with the help of a painless wiring system.
the old speedometer was a cable operated, would appreciate any help fitting a new speedometer.
Old Aug 26, 2011 | 01:13 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Re: speedo swap
You will have to get an adapter that turns the electronic signal into a mechanical signal to turn the cable for the speedo. Or, you can swap out the gauges for electronic versions and simply program the new electric speedo to the correct pulses per mile. Any electric speedo will come with instructions telling you how to program the unit to the output signal coming from the trans.
Old Aug 26, 2011 | 02:37 PM
titan7's Avatar
Car: 1985 camaro
Axle/Gears: 3:42
Re: speedo swap
thank you for the information,I've looked into those options in the past few days,The new electronic speedometer seems like the best choice.
Jorlain
Aug 24, 2022 05:11 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
stickychinsac
Aug 31, 2015 06:06 AM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
beachrodder
Aug 7, 2015 04:27 PM
