4th gen seats
Old Aug 18, 2011 | 08:50 PM
bigd077770's Avatar
Car: 1998 Trans Am/1992 Camaro RS
Engine: LS1/5.0L TBI
Transmission: 4L60E700r4
Axle/Gears: 3.23/2.73
4th gen seats
i put seats from a 1995 camaro and the driver's seat rocks back and fourth. it has the adjustment to slide it closer and farther form the dash like a regular seat then there's another adjuster to the right idk if that has something to do with it or not, and help would be great. i can post pics soon, i got to school 5 days a week 1 to 9 so i dont get much work done especially with no garage
Old Aug 21, 2011 | 07:00 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
Re: 4th gen seats
the other control lets you change the bottom seat angle.it may be missing the return spring.
Old Aug 21, 2011 | 11:58 PM
bigd077770's Avatar
Re: 4th gen seats
okay thanks, ill take it out, flip it over and check it out. are the 4th gen seats lower than the third gen? seems kinda low when i sit in it (im about 5'8 not too short)
Old Aug 22, 2011 | 01:01 AM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: 4th gen seats
Yes, the 4th gen seats are shorter than the 3rd gens. At 6'5", I'm glad they are & one reason why I have had them in all my 3rd gens.
Old Aug 22, 2011 | 01:39 AM
MAC_87's Avatar
Car: 1987 IROC-Z
Engine: 5.7L
Re: 4th gen seats
How much lower are they?..
Old Aug 22, 2011 | 01:40 AM
bigd077770's Avatar
Re: 4th gen seats
Do yu know what the diff is? Id like to raise it a bit could i shim the seat possibly?
Old Aug 22, 2011 | 01:47 AM
bigd077770's Avatar
Re: 4th gen seats
could i put 2 washers on all for corners of each seat between the tracks and floor?
Old Aug 24, 2011 | 11:03 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Re: 4th gen seats
When I removed my seats from the salvage yard donor, I took the factory washers that were in place. I just installed the 4th gen drivers seat last night but only added one washer per bolt (as opposed to the at least 4 that were on the donor car). To be honest, if you are attaching the seat to a 3rd gen power seat track (like I did), you shouldn't notice any height difference. Lastly, although you will occasionally read differing opinions about comfort (4th vs. original 3rd). I noticed an immediate better difference with the 4th compared to my 150k 3rd gen seats.
Old Aug 24, 2011 | 11:30 PM
bigd077770's Avatar
Re: 4th gen seats
when i took my 1995 seats out from the donor car for my 84z ithere were no washers in the car under the seats
Old Aug 24, 2011 | 11:48 PM
bigd077770's Avatar
Re: 4th gen seats
i have to take the driver's seat out this weekend to look at the tilt mechanism so ill just throw some washers under it and see how it feels.
Old Aug 25, 2011 | 09:56 PM
zenish's Avatar
Engine: 305 tbi
Re: 4th gen seats
i cut four pieces of 1.5 inch pvc one inch long and put them between the seat and seat brackets using two inch screws from the hardware store.now i can see past my cowl hood.
Old Aug 25, 2011 | 10:34 PM
bigd077770's Avatar
Re: 4th gen seats
Do you have any pics?
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
cam-mike
Aug 24, 2015 07:23 AM
