Rearview Mirror WILL NOT stay up
Old Sep 10, 2011 | 08:50 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
this thing fall off if someone farts within a mile, its getting old, i tried every over the counter type of rearview mirror glue, im doing all the directions, cleaning the glass and mirror button, using the prep, holding it on over a minute, letting it sit up 48 hours, i even tried scuffing up the button with the wirewheel. car is stored inside, hardly ever in the sun, the mirror is a standard GM compass/autodim, had the new camaro dice haning on it, even took them off. it has feel off 5 times in one month and 2 i had never moved the car
should i just take it to a glass place and let them deal with it or is there something i do not know, i have never had one fall off like this ever on alot of cars
Old Sep 10, 2011 | 09:12 PM
shortyskater's Avatar
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
Re: Rearview Mirror WILL NOT stay up
I've always had luck with the regualr permatex rear view mirror stuff. If you want to get serious about it and not want it to ever come off, try gorilla glue.
Old Sep 10, 2011 | 09:20 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i had the same problem with my old truck , did all the same glue kits . finally just used 2 part epoxy on the mount plate . taped it in place 24 hours , re-installed mirror done . this was when i lived in the KEYS , you have seen my old truck & know how i have beaten it . worked for me , see you tomorrow .
Old Sep 10, 2011 | 11:06 PM
89RS_82Z's Avatar
great ideas
IDK tho i may let the glass place deal with it, lifetime warrenty
Old Sep 10, 2011 | 11:46 PM
91ls1t56's Avatar
Car: 91 Z28
Axle/Gears: Moser 9" 3.70 35 spline wavetrack
I had the same problem tried everything. Nothing worked. I got some 2 part epoxy for metal and glass at the parts store, still didn't work it got hot one day and fell off again. Here's the trick like I said it was hot the day it fell off and I had put it on the first time when it was cooler out, but I put it back on on that hot day and it has stayed up ever since you may want to try that. My car has some pretty stiff suspension and it has held up so far. Yeah its missing in my avatar.
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
lewandom
Oct 1, 2015 08:15 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
