Consensus On Dash Pads
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
Re: Consensus On Dash Pads
those are both for camaros? why does one have covers and one doesmt, have i really never taken notice to this?
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
one would think with so many interchangeable parts between them that theyd be the same yanno. i like the bird one better personally.
Engine: 5.0 EFI
Well,I broke down and bought a used dash pad,AGAIN.Couldn't pass up on the price and it is in excellent condition.Hope this one last longer than the others.
Car: Camaro RS
Engine: obd2 350 lt1
So my pad is cracked on the corner. I don't want the glare or texture of a painted one so I think ill try my hand at covering it with some leather. Maybe find some nice 4x6 speakers and grills and mold them in flush should look nice.
Engine: 5.0 EFI
Engine: 5.0 EFI
The dash cover with shipping was about $140.00 that was with a discount from Classic.I see your from the Poconos,that's where I traveled to get the dash pad that I covered.
Car: 1984 Firebird
Axle/Gears: 3.42's
Thanks man... my original one just cracked recently... probably going to pick one up after I get it back on the road.
Engine: 5.0 EFI
I'll sell you this one,it has the dash pad glued to it!!!
and also.it's for a 82-84
Car: 1984 Firebird
Axle/Gears: 3.42's
Right now, I'm concentrating on getting it inspected. New tires are coming today, then I need a vss, and some air dam plastics. Its been 12 years since it was on the road and its KILLING me. If you still have it in a few months, I'll check on it. If you can sell it to someone else in that time, by all means, please do.
Car: 1985 Firebird & 1992 Camaro B4C 1LE
Engine: 310 LS1. & 305
Transmission: TH350 & T5
Axle/Gears: 9" 3.73
Surprisingly this isn't the first time i've heard of using it. I was using a really good product from Black Magic I think it was, called Ice. Worked very well. But I am switching to baby oil soon after seeing how well it has worked for others on the interior restoration threads.
I did the same with an uncracked dash pad I got for our 86 SVO, only I coated it, wrapped it in foil and then wrapped it in seran wrap and then stored it in our closet for a couple of years until I got to restoring the car. It's in the car now, and looking good as new.
I just recently received _another_ uncracked dash pad for our 92 B4C, and will be treating it the same way. I'll probably NOT wrap it and leave it for so long, but will probably let it sit for a couple of weeks before wiping it down and installing it.
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
the vaseline will keep it new looking until it dries and then it will crack it like no other. i always used suntan lotion
Vintageracer
Sep 24, 2017 12:34 PM
