Front seat belt operation?
Old Dec 15, 2011 | 01:33 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
What is the name for the type of locking mechanizum used in our cars? I know its not a traditional yank hard on the belt type and seems to work with the cars momentum.
I just found this and they are calling it a "Vehicle-sensitive lock" So I guess thats it. Heres how they discribe how it works. = It is based on a pendulum swung away from its plumb position by rapid deceleration or rollover of the vehicle. In the absence of rapid deceleration or rollover, the reel is unlocked and the belt strap may be pulled from the reel against the spring tension of the reel. The vehicle occupant can move around with relative freedom while the spring tension of the reel keeps the belt taut against the occupant. When the pendulum swings away from its normal plumb position due to sudden deceleration or rollover, a pawl is engaged, the reel locks and the strap restrains the belted occupant in position.
OK,then that means that as long as the car is stopped or driving normally you can yank on the belt a dozen times and it still will not lock.
Old Dec 16, 2011 | 04:10 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Front seat belt operation?
I think it's called Inertia
1992 Trans Am
May 10, 2023 07:19 PM
MORREALE5
Sep 13, 2015 09:16 PM
zayne0
Aug 24, 2015 07:22 PM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
scottmoyer
Aug 9, 2015 10:18 PM
