Window Alignment
Old Dec 23, 2011 | 05:41 PM
redzee85's Avatar
Car: 1985 z28
Engine: 5.0 LG4
Transmission: Built 700R4
Axle/Gears: 3.08
Window Alignment
Hey everyone I have a 85 z28, I installed new door panels and the new seal and black piece that attached to the top of the door panel. I also had the window seal replaced on the outside of the car by a bodyshop. They loosened up the window by the bolts on top of the inside of the door to put them in. When they tightened everything back up I believe they tightened it too much because my passenger window rolls up very slowly especially when it gets to the top and it didnt do this before.....you can even see the smudge marks on the tint from where the pieces holding the window snud is too tight....Does anyone know what the proper adjustment is? or should i just loosen and try till i get it how it should be??
Old Dec 24, 2011 | 03:42 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Window Alignment
they probably put the window back exactly where it was, which since the weatherstripping is still new it sticks out further. you can take the door panel off and loosen everything up and readjust it.
Old Dec 24, 2011 | 07:42 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
if you have a HELM book it should be in the body section and it breaks it down by what bolts do what action. if you dont have a HELM book (not hayes) i sugguest getting one as they are miles better than the hayes book and pay for themselves quickly.
if not, this may help ya out: https://www.thirdgen.org/windowadjust
Ed1LE
Sep 30, 2018 09:14 AM
Fireslash
Apr 11, 2016 06:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
meeklay812
Oct 1, 2015 03:46 PM
