High-beam bulb burned out
Car: 87 Camaro
And I'm trying to get to it but it's covered by the speedometer face which I can't get off because of the speedometer needle. How do I get to the bulb?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: High-beam bulb burned out
Remove the cluster.
JamesC
JamesC
Car: 1986 iroc-z
Engine: 5.0 tpi
Axle/Gears: stock.
should be able to pull the cluster out, just reach behind and disconnect the speed-o cable, once out find the bulb holder twist and pull out.
