how to feed seat belts though asb headliner?
Old Jan 7, 2012 | 11:39 AM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
Hey everyone, first off sorry for the miss spelling I typed it in wrong and didnt catch the mistake. Anyways I want to install my abs headliner but I was running into some issues that I am not sure what I should do? How do you feed the seat belts thought the headliner with out cutting a slit to the sides? I do not see a way to feed the belts though It?
its abs plastic coverd in cloth, I do not remeber were I bought it from ( maybe hawks?) I would like to install this tomorow so any help would be great!
Old Jan 7, 2012 | 11:46 AM
mrrman's Avatar
Re: how to feed seat belts though asb headliner?
I had the same issue and cut the slit in it...i peeled back the liner and just cut the ABS portion then reglued the liner back.
Old Jan 7, 2012 | 12:04 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Do you by chance have a picture of this?
Old Jan 7, 2012 | 04:44 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
You need to cut slits. The trim panels at the top that lead into the sail panels should cover the cuts.
Old Jan 7, 2012 | 07:02 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
cover the cuts with what?
Old Jan 7, 2012 | 07:10 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Old Jan 7, 2012 | 07:15 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Axle/Gears: 3:73
Thank you.
RyanJB
May 7, 2016 06:23 PM
codeysabatini
Sep 20, 2015 11:36 AM
MORREALE5
Sep 13, 2015 09:01 PM
iroczguy86
Sep 13, 2015 02:22 PM
MORREALE5
Sep 10, 2015 08:58 AM
