dashboard won't go back in properly!!
Car: 1991 Z28
Engine: 5.7 TPI
I had to replace my heater core- and no, I couldn't reach all the heater box screws without pulling the dash, AND 'NO' IT DIDN'T TAKE JUST A COUPLE OF HOURS, IT WAS A PITA!
Anyway, I had the dash pulled out about 6 inches and when I went to put it back, it seemed to resist for some reason. I can get it on at the top, but the bottom doesn't want to line up and seems to be hung up somehow in the middle behind the center console. I have it in sort of in the meantime, but it will have to come out and be reinstalled at some point, so everything is situated correctly- my center console wants to go further forward but can't at the moment and the top is distorted slightly and does not want to line up with the center vents.
Has anyone run into this problem and have an easy answer for me when I tackle this again on the weekend?? Just how far do I have to disassemble this thing?
Engine: 4++,350 & 305 CIs
Re: dashboard won't go back in properly!!
Maybe because nobody takes them out to change a heater core
I have had many of them out and its more of a pain than its worth.
You will have to keep looking around to find whats keeping it from going back in properly.
Car: 1992 firebird. 1984 Trans Am
Engine: 3.1L. L76 coming soon
Transmission: 700R4. T56 coming someday
I did mine years ago but I don't recall any problems with it going back in. And I ounce had my Trans Am dash completely out and when I put it back in it was getting stuck up on the harness on the top. I would just have a second set of eyes help you look to see what your getting caught up on.
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
colton_carlson
Mar 8, 2019 12:21 PM
