How much wind noise is in your cockpit?
Car: 1984 Camaro Z28 Clone
Engine: Bored .030, vortec sbc350
Transmission: Built T5 WC
Axle/Gears: 1999 Torsen 4:10 Locker
How much wind noise do you guys get from your windows? I have brand spanking new seals on everything and have adjusting the windows and I still get a heck of a lot of window noise from my windows. I know its not going to be perfect from a 30 year old car. I don't mind it to much but passengers always complain.
Is this just what you get, or is there something I am missing that I should do?
Car: 1986 Camaro
Engine: 355 N/A mind 400hp build
Re: How much wind noise is in your cockpit?
I get a LOT of wind noise from my windows....
But I never drive with my windows up either lol so I guess it doesnt count?
The only time my Camaro comes out to play is when its sunny and dry
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
have you replaced the triangle seals, because when i swapped some new ones in my noise inside dropped dramatically
Oh yes, that helped HUGELY but still...pretty good amount of noise coming from the seals
Transmission: 5spd
yeah, i know alot of noise comes from a slightly too large door fender gap that could be causing it, but if its not a major issue i wouldnt treat it like one
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I didn't have any trouble after I installed new weatherstripping,I Have to crack the window to close the doors because it's sealed so tight.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I have a little bit with my GTA. It's got all original gaskets, and the windows are a little sloppy. The IROC is nice and quiet. The window tracks are tight, and I've got sof-seal window/t-top gaskets.
Car: 1991 camaro
Engine: 3.1L V6 dynomax exhaust
Transmission: 700r4 auto
Axle/Gears: 89 iroc-z 9bolt disc+posi 3.27
Transmission: 5spd
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Car: 1991 camaro
Thank you. I replaced all my weatherstripping except for the triangle seals. So now I'm going to try replacing the triangle seals. What other adjustments can be made.
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
I get lots of noise from the area around my mirrors/triangle seals, but by just looking at them they look okay. I'll probably go ahead and replace them anyways.
Transmission: 5spd
there kin of a problem area on thirdgens, mine are new, all the weather stripping is however its just a bad design, airs gonna get in an make noise, nothing short of ajusting the doors way too high will stop it, which reminds me i need to adjust my doors again and tighten the bolts
Transmission: 5spd
Car: 88 Camaro
Engine: L98 350
Very little wind noise on my 88, but the road noise makes up for it. Mostly original stripping except for the lower window seals.
Car: 1985 Pontiac Trans Am
Transmission: BW T5, Hurst Short Throw Shifter
Axle/Gears: 3.70 Posi
Could barely hear the passenger before I replace the weather stipping for the T-Tops. Took a bit of work, but it was well worth it!
Car: 1986 Chevrolet Camaro Z28
Engine: 350 V8 4bbl
Transmission: Automatic 700r4
Axle/Gears: 2.73 Open Diff
I've always either got the windows down, or the stereo up so loud that it drowns out the wind noise anyways haha.
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Mine has very little wind noise... all old factory seals and sagging doors and everything.
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
Mine used to be deafening above 80mph. It turned out to be the centre bar, which holds the T-tops down. It had lifted slightly, allowing the tops to rise at speed. Bonded back in properly now, much better
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
My 89 is super quiet. My 97 firechicken sounds like a freakin prop plane with no windows, 75 mph i cant talk to my wife sitting next to me...
Car: 1988 Trans Am GTA
Engine: 5.7 TPI
completely silent until i get about 80 km/h then its ridiculous, I prefer just driving down the highway with the windows open..
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
None, with 26 yo seals and slight gaps at the tops of the windows. Fuel pump is louder, and exhaust drowns them both out completely.
Car: 88 Pontiac GTA and 4 Camaros
Engine: 5.7
Your post really caught my eye lol!!!! My husband and I fly P51 Mustangs and do many airshows....We also have a small used car lot of 3rd gens. On my daily driver I have to admit....theres more wind noise in that car then there is in a P51 Mustang in a straight dive!!!! I would hope new weather stripping would eliminate all noise. Even though the car is 20 something years old...the shape shouldnt have changed....therefore youd think new weather stripping....if installed right would make it sound new. If not....Im not sure Id want to spend the small fortune to have mine replaced!
Transmission: 5spd
well weatherstripping alone wont do it, the doors need to be perfectly aligned, if you have ttops there weather stripping needs to be good, make sure the car sits in the sun for a good while take the ttops out for a few minutes, then put m back in after an hour or so in the sun, i dont take mine out much, personally i just like the idea of glass as a roof and being able to see the sky
and anyways........also the (idk what to call them) rubber/foam blocks at either end of the doors need to be in good shape, mine are kinda chewed up, idk where the hell to get new ones, or cheap window sweeps for that matter. all needs to be good because it'll all let in wind/water/ice frozen locks because your window sweeps are rotted away sucks, so i no longer lock my doors
and anyways........also the (idk what to call them) rubber/foam blocks at either end of the doors need to be in good shape, mine are kinda chewed up, idk where the hell to get new ones, or cheap window sweeps for that matter. all needs to be good because it'll all let in wind/water/ice frozen locks because your window sweeps are rotted away sucks, so i no longer lock my doors Joined: Jan 2009
Car: 1990 GTA
Funny cause I have very little wind noise in my car, then again my door panels have never been off and I'm sure that the big clear seal that covers the regulator and everything else under the panels might have a lot to do with it, cause I know when most people do any kind of work in the door those things never seal back up right and some people even just rip it off, I work in a dealer and have been in cars after a tech didn't put/seal it back and you can hear wind coming in, new cars by the way.
Car: 87 GTA
Engine: 5.7 TPI
I made new water shields with heavy duty FEMA plastic, even used FatMat under the door panels. I still hear wind noise, but like I said, most of it is around the mirrors.
Transmission: 5spd
do you know the foam/rubber "blocks" i'm talking about, it could be them if there a little torn up
Down side of having rimless windows. I've noticed that almost all sports cars with rimless windows are a bit noisy inside. Minus these new ones that actually self seal when you close the door. Like the Corvettes and newer BMW's
I got very frustrated trying to chase down a loud wind noise from pax side of the kids car after new door and T-top seals and adjustment, which is what I thought the noise was. Turns out the pax mirror was hit or bumped inward, making the air gap smaller. Isn't really noticeable until you start looking close and comparing to driver side. Going to have to tweak this at next door disassembly...
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Wait...is this with or without my Ford-loving buddy riding along?
mine has a lot of windnoise as well. i have gotten most other work done and im about to do an engine swap. but after the engine swap is done i want to get all the weather stropping done. and i need to get the door pins and bushings. and then align the windows correctly. man i think my wife is going to cut something off before i ever finish my car LOL!!!!!!!!
I get some kind of whistling. Sounds like I'm riding on a jet, only not as loud.
Its not loud enough to be annoying, though I'd prefer no wind noise while on the road.
Transmission: 5spd
adjust them, those little things that hold it upright, and the door itself
Car: 1991 RS
Engine: Stock 305
Transmission: Stock
Axle/Gears: Stock
Mine after I get over 30 starts getting loud.... Then at about 65 70 you couldnt hear someone talk or your own voice :P
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Or:
Depends what I've eaten
boom boom
boom boom
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
sjorgens
Oct 1, 2015 07:54 PM
