i really need help with my seats
Car: 1982 Camaro Berlinetta
Engine: GM crate motor Goodwrench 5.7 350
So i was driving down a main road when all of a sudden my chair reclines all the way back, scared the **** out of me haha. This problem has been gettin worse and worse since, like leaving a stop light a little faster than a grandma it happens. you can hear a ratchet as it goes down so i thought it might just be whatever it is that clicks into the ratchet gear not securing in the ratchet fully. I took off the upper cover on the adjuster lever and sprayed some silicone lube in, thinking it'll be better by not gumming up like WD-40. Anyways long story short, i think i just lubed the ratchet more and made it easier to slip because now the seat is moving almost all the time and at a faster pace. so does anyone know whats going on, or are you having a similar issue and how can i fix this? my thirdgen is my daily driver so i need to know ASAP! please help if you can.
Re: i really need help with my seats
nvm, i went to the recker and picked up a working mechanism
MrPackstin
Oct 25, 2017 08:09 PM
