Right interior blinker light not working?
Old Mar 7, 2012 | 02:55 AM
Firechicken86's Avatar
Car: 1989 Trans am GTA
Transmission: t56 6 speed
Axle/Gears: 3.45
I was driving my car today and noticed that when I got to indicate right, the green arrow won't light up but the left one will and it worked before. Could this be a blown fuse or a bad lightbulb?. I'm hoping it's a fuse or something because I'm not looking forward to taking my dash apart just to replace a lightbulb. thanks in advance
Old Mar 7, 2012 | 03:15 AM
lectric80's Avatar
Car: 83 Z28 T-top
Engine: 350 carb'd
Re: Right interior blinker light not working?
No fuse is going to cause that, it is either the socket lost contact or more likely a bad bulb. Need to do that on mine now that I think about it, the right side is out on mine and I know it is a bad bulb.
Old Mar 7, 2012 | 03:36 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
If your right hand turn signals(front and back) are working,then it's the bulb in the cluster gauge.
Old Mar 7, 2012 | 03:58 PM
Axle/Gears: 3.45
Nevermind guys, I went into my car this morning and tested it out and it for some reason decided to work again
Old Mar 8, 2012 | 12:01 AM
lectric80's Avatar
Car: 83 Z28 T-top
Engine: 350 carb'd
I would be checking the printed circuit board then, it is likely the socket connections have worn through the copper causing an intermittent problem. They do wear over time, and usually right at those connections.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
justin57
Aug 20, 2015 07:05 PM
Omega
Aug 10, 2015 12:46 PM
