new dash pad?
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: new dash pad?
http://www.classicindustries.com/
1982-92 CAMARO DASH PAD
Replace your original warped or worn out dash pad in your 1982-92 Camaro with a high quality OER reproduction padded dash. Manufactured to OE specifications for an original fit and appearance. The existing mounting clips may be removed from the original dash and used to install this reproduction. Available in black only. OER premium quality interior paint may be used to match desired color.
Important: When replacing the dash pad, the foam support blocks often get damaged. These are available as pt# 14046089
Note: Mounting holes are not pre-drilled. Shipped double oversize.
Part Number: # 12511119
In Stock
$429.95 ea
Qty:
In Stock
$429.95 ea
Qty:
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: new dash pad?
There are, however, differences in the run of pads, so the above is a bit off the mark. More info below:
https://www.thirdgen.org/forums/hist...vs-1984-a.html
BTW, good OE pads are out there if you're patient (I paid $50 for a mint pad that I stumbled on in a bone yard).
JamesC
Vintageracer
Sep 24, 2017 12:34 PM
