Cruise Control Bracket
Old Apr 28, 2012 | 03:16 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Hey guys is this the cruise control bracket.I'm trying to locate the cruise control modual,if this is it,then I found it!!!!!
Old Apr 28, 2012 | 03:57 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Cruise Control Bracket
it was under the dash on top of the steering column? Looks like the bracket but no module
Old Apr 28, 2012 | 04:20 PM
mantaguy's Avatar
Engine: 5.0 EFI
I took the black box off!!! this is on the right side of the I/P
The black box was connected to the bracket is that the C/C modual???
Old May 3, 2012 | 05:33 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Yes, that's the module. The black box, not the silver one.
Old May 3, 2012 | 05:58 PM
mantaguy's Avatar
Engine: 5.0 EFI
Thanks Mav,that's what I thought!! I bought a new turn signal switch,I'll try that 1st then move on to the next if that's not the problem.
Old May 3, 2012 | 05:59 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Also check the brake switch (has a big vacuum line on it)... May have come out of adjustment or the vac hose may have cracked due to age.
Old May 3, 2012 | 08:02 PM
mantaguy's Avatar
Engine: 5.0 EFI
I checked the vacuum,it has good vacuum
Hotrodboba400
Dec 10, 2019 07:07 PM
Jlanz55
Sep 6, 2015 02:35 PM
rsrookie
Sep 5, 2015 07:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
