help with carpet!!
Old May 12, 2012 | 06:22 PM
spdhawk77's Avatar
Car: 89 Formula
Engine: 305 T.B.I.
Transmission: 5 Speed Manual
help with carpet!!
I know some of you have installed new carpet. How did you get the best results? Should I glue it down or heat it up or leave it alone? I have lumps in the carpet that lay down easily when pushed but wont stay?/ Suggestions would be appreciated. :-)
Old May 12, 2012 | 08:39 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: help with carpet!!
What I have heard is one needs to lay the carpet out in the sun[black top the best] for a few hours before install.
Old May 12, 2012 | 08:45 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Don't glue anything down. Let the carpet lay down on the floor pans all by itself. Getting out wrinkles can be tricky and a time consuming thing to do. I used an iron on low heat to help get the carpets to lay down. I also kept rubbing and massaging it in the areas that needed the most help like around the rear hump. Most of the carpet is under the seats any way so concentrate on the wrinkles in places where they are most visible.
starliner
Feb 9, 2016 08:18 PM
1992Z28!
Nov 19, 2015 07:33 AM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
indygene
Sep 26, 2015 11:21 AM
