Anoyying Power windows!
Old May 24, 2012 | 10:56 AM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
So on my z28 my dirver side window makes this very anoyying noise i made i video and uploaded on youtube so if you could check it out and give me some feedback ide appreciate it, thanks!
http://www.youtube.com/watch?v=FU_p7...ature=youtu.be
Old May 24, 2012 | 04:13 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: Anoyying Power windows!
Wow, that's one of the squeakiest windows I've heard. Not sure how good you are at removing door panels, but I'd take the panel off and look to see if there's anything obvious like a piece of trash stuck in the window motor gear, or possibly something jammed in the window track.
Old May 24, 2012 | 04:38 PM
Coyote850's Avatar
Car: '83 Z-28
Engine: 5.0 CFI
Transmission: 700-R4
Damn...........thats creeky. Might be the tint has come off and is rubbing something. Best thing to do is take the door panel off and run the window up and down to localize the source.
Old May 24, 2012 | 04:59 PM
WickedCrazy's Avatar
Car: '91 Firebird '85 Firebird
either way remove that shitty tint. It's possible that the window guides are down to plastic and have lost their felt lining. that would explain the rips in the tint. Also that sounds a lot like your motor is shot. If the door seems to shake then that would be your problem.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Sep 13, 2015 09:07 PM
stalkier
Aug 21, 2015 01:54 AM
