Seat Brackets
Old Jun 5, 2012 | 08:53 AM
Dels383TA's Avatar
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: 5 Speed
Axle/Gears: Ford 9"(Moser),4:11s,locker,31splin
Seat Brackets
I am looking for a seat of aftermarket seat brackets, I have a seat of seat I just put in, but had to make a rail to use the stock base and sliders, I have a set of Sparco sliders, just not the floor mount.
I just dont want to spend 200+ on a set of mounts, is there a cheaper set that I have not found. Any help would be great.
Old Jun 5, 2012 | 07:33 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Seat Brackets
I have a set of Procar by Scat sportsman seats I am putting in and am dealing with the same issue. Procar sells direct fit brackets but they are $150 or so for the pair and I've heard they have you sitting an inch higher. What I ended up doing is using the set of aftermarket sliders for the seat(s) and just welding on a new tab on each end of the slider. I looked into simply re-drilling the stock brackets to fit, but since they are curved and my seats are flat I chose not to. I will try to post pics when I am done, probably in 2-3 weeks as I have other projects.
HP52TA
Feb 3, 2018 10:51 PM
MORREALE5
Sep 13, 2015 09:01 PM
Hello, Michael
Sep 11, 2015 01:10 PM
MORREALE5
Sep 10, 2015 08:58 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
