no lights help me please
Old Jul 5, 2012 | 09:10 PM
darkness878's Avatar
Car: 1987 iroc z camaro
Transmission: 700 r4
Axle/Gears: no idea
So my headlights come on and work i replaced the switch thinking that was the problem and it turns out it wasnt i Have no running lights dash lights or tail lights the fuses are fine there is just no power going to them how could this happen out of no where ?
Old Jul 7, 2012 | 12:49 AM
Axle/Gears: no idea
Re: no lights help me please
can anyone help ? all fuses are fine bulbs fine just no lights besides headlights brand new switch in there to is there a fusable link or something somewhere
Old Jul 7, 2012 | 05:09 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
slip under the dash and put your feet in the headrest so your looking stright up into the under dash, pull the fuse block (7mm nut driver) and look to the right of the fuse block. there "should" be a chunk of harness thats larger than the rest and roll it around to the other side and see if the insulation has been broken thru.
this happened on my 89 and on a friends 86 T/A. this is a sugguestion, my lights never blew the fuse, just acted real weird.
Old Jul 20, 2012 | 11:27 PM
Axle/Gears: no idea
anything else i did that and it was fine :/ a wire touched a ground down by my radio idk which one it was then they all went out helppp
Old Jul 24, 2012 | 05:38 AM
08racer8's Avatar
Car: 86 iroc z 91 rs 87 iroc
Engine: 305 tpi
Transmission: auto
Axle/Gears: 3.23 posi disk brake
check your fuseable link down by the starter and check the ground on the core support
Old Jul 27, 2012 | 08:52 PM
Axle/Gears: no idea
still no luck with any of this which wire down by the radio is connected to the lights that one touched a ground and then they all went bye bye except there is still power to the headlights its not the switch that is bad
Old Jul 27, 2012 | 11:17 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
have youchecked the fuseable links down by the starter?
Old Aug 4, 2012 | 08:39 PM
Axle/Gears: no idea
i checked those links there all fine what else could it be ?
Old Aug 12, 2012 | 10:15 PM
ogg__666's Avatar
Car: 1988 iroc-z28
Engine: 305 tbi
Transmission: new 700r4
Axle/Gears: um 2.77 i think
im having the same prob with my 88 iroc having a hell of a time figuring it out im looking at the wiring but have no idea where the org power wire gets its power from .... my head hurts !!
Old Aug 15, 2012 | 01:02 PM
89demon's Avatar
Car: 91 RS
Axle/Gears: Posi 3.73
I feel all of your pain I just removed the tbi that was on my 350 and was going to go tpi but decided to put a carb on her and now.....my wiring is going crazy! Headlights work...tail lights and dash lights but my blinkers aren't working (the right turn arrow on the dash stays on..nothing outside though) and the third tail light is out as well. I pulled the buzzer out as well because when you turned on the head lights...buzzer would stay on. I have to rewire my gauges too. the wiring in this car is a cluster. idk
Old Dec 25, 2014 | 11:44 AM
GIBryan's Avatar
I have the same problem no brake lights tail lights or turn signals. The weird things my gauges act funny when I turn the lights on. As soon as I find the problem or solution I'll post it.
Old Dec 26, 2014 | 10:52 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
You shorted the lighting circuit with the lighting lead to the stereo (dims display when lights are on). Probably a ground or power feed to head unit burned through and ground ing out in the dash. Strange that the fuse isn't blowing though. Check the radio power fuses.
TrevinE
Sep 14, 2015 03:20 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
