Ashtray hook up
Old Sep 2, 2012 | 03:44 PM
Haber's Avatar
Car: 1987 Pontiac Firebird
Engine: 5.7L T.P.I.
Ashtray hook up
I'm installing new console in 87 firebird. Power source through lighter was never hooked up but appears the wiring is present. There is a black yellow n orange wire, does anyone have a clue how to hook these three wires up to ashtray power source?
Old Sep 3, 2012 | 03:32 AM
Nunazet's Avatar
Car: 1985 Trans Am
Engine: Stock 305 converted to carb
Re: Ashtray hook up
Black wire (ground) goes to the outer shell of the Lighter socket, the hot wire (+12v) goes to the center connector. Just two wires.
Old Sep 3, 2012 | 07:29 AM
Haber's Avatar
Engine: 5.7L T.P.I.
Re: Ashtray hook up
Thanks, there is two live wires present at same location, orange and yellow. Do u know what the other wire would be for?
Old Sep 3, 2012 | 01:13 PM
Nunazet's Avatar
Car: 1985 Trans Am
Re: Ashtray hook up
No extra yellow wires on mine. So a picture is worth a thousand words. This is all the wiring in the console of my '85 TA.
Working from the bottom up.
Brown wire to the parking brake.
Orange and black plug into the glove box light.
The blue and clear plugs are power windows.
Light bulb laying on the shifter with gray and black wire goes in gear indicator.
Orange and black plug into cigarette lighter. They come out of the harness with the wires that plug into the shifter.
Up with the radio wires there is a pair of hot wires ( orange and brown ) that feed the radio. They are spliced into a yellow and orange pair. One is switched and the other is constant 12v+.
Hope that helps. It's all I got
Old Sep 3, 2012 | 07:07 PM
Haber's Avatar
Engine: 5.7L T.P.I.
Re: Ashtray hook up
Thanks, that helps me out alot!
Old Sep 4, 2012 | 04:40 PM
W3DO1TB1G's Avatar
Re: Ashtray hook up
Light bulb laying on the shifter with gray and black wire goes in mf Orange and black plug into cigarette lighter. They come out of the harness with the wires that plug into the shifter.
Wow man, thank you so much for the in-depth description. I was planning on installing an ash tray but was very skeptical.
Old Sep 5, 2012 | 01:43 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Ashtray hook up
That other wire your talking about may be for the light switch for the consol lid or the switch for the emergency brake handle.
Z28/ZR1
Oct 23, 2015 01:04 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
Derrick86
Oct 1, 2015 05:12 AM
Gordonr1973
Sep 29, 2015 11:59 AM
