seat removal.
Old Sep 29, 2012 | 08:31 PM
crazybird's Avatar
Car: 1987 firebird
seat removal.
There are four bolts holding the seats in correct? I think I see the front two. Can anyone give me some easy removal tips? I did a search and couldnt find a simple answer.
Old Sep 29, 2012 | 08:49 PM
Lmancha96's Avatar
Car: 1992 Camaro (Z28 Clone)
Engine: LB9|TPI
Re: seat removal.
Yes there are four bolts.
From what I remember there isnt to much you have to do.
Just unbolt the seats and pull them out.
If you have electric seats, im not sure but I think there is some stuff you have to disconnect.
You also might have to remove the seat belt guide from the seats.
Old Sep 29, 2012 | 09:07 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: seat removal.
Undo the lower screw on the seatbelt guide and pull the belt out of the guide.
Put the seat all the way to the back using the lever (not the reclining lever, the one under the front of the seat). Undo front trim and 2 nuts.
Put the seal all the way forward and undo the rear trims and 2 rear nuts. If necessary (power seats), unplug wire harness and lift seat out of car.
Old Sep 29, 2012 | 10:11 PM
Sidethumper's Avatar
Car: 87 Pontiac Trans Am
Engine: Lapouttre Racing 350
Transmission: Rebuilt 700r4 Mild shift kit
Axle/Gears: 10 bolt 3.23 posi w/disc brakes
Re: seat removal.
They can be a pita to remove if there is rust on the bolts. Just a heads up.
Old Sep 30, 2012 | 12:45 AM
Spaceboy1980's Avatar
Car: 1990 Camaro RS
Engine: L31
Re: seat removal.
I swapped the seats in my camaro and on the passenger's side I had to take the tracks out with the seat. In hind sight it would have been easier to do the drivers that way also.
Old Sep 30, 2012 | 03:23 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Re: seat removal.
you'll also need metric sockets. I believe it's a 13. Some penetrant applied first will help but spray lightly so as not to stain the carpet. The rear seat bottoms are held in by a single nut in the front middle.
Old Oct 3, 2012 | 02:11 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: seat removal.
If you can get to them, try spraying penetrant from the underside too as the bolts go all the way through the body and can sometimes be accessed from underneath.
MrPackstin
Oct 25, 2017 08:09 PM
GageBrand
Oct 22, 2015 02:30 PM
Briandrex
Oct 5, 2015 06:20 AM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
kitt23
Sep 26, 2015 07:48 PM
