White Lithium Grease on Plastic??
Old Nov 7, 2012 | 11:51 AM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
So I finished installing my heater core two days ago, and before I put the dash back together, I sprayed some white lithium grease on the assembly that pivots to move the heater door open and closed..
Should I have not done that? Or is it going to cause any problems with the plastic? I know the moving parts themselves aren't plastic but the area around it is..
It's not hard to access to clean it off if need be, I just really need to know if the grease is going to cause any problems down the road..
Any suggestions on a different type of lube for it?
Old Nov 7, 2012 | 12:11 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Re: White Lithium Grease on Plastic??
No, Mine Came From The Factory With That Grease On It.
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
MrPackstin
Oct 25, 2017 08:09 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
89bird2.8
Sep 25, 2015 09:21 AM
