For the guys who have done sound deadening...
Old Dec 22, 2012 | 10:04 AM
soul.justice's Avatar
Car: 1985 Firebird Trans Am
Engine: 305 4bbl
Axle/Gears: 3.08
What product did you use? How much of it did you need? And what would you have done differently? Sound deadening is going to be the next project I tackle since I'm hoping to get some new carpet in the next few months. Any and all insight will be appreciated.
Old Dec 22, 2012 | 10:10 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: For the guys who have done sound deadening...
I use fatmat. No complaints.
Old Dec 23, 2012 | 05:32 PM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
+1 for fatmat. Worked well and reasonably priced.
Old Dec 23, 2012 | 06:22 PM
LHernandezJr's Avatar
Old Dec 24, 2012 | 08:27 AM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
Good idea with the neoprene. When I was ordering my seat covers mr mike recommended I used closed cell foam which is like beer koozie material. I'm going to use that in my hatch area and see what happens.
Old Dec 25, 2012 | 03:35 PM
micktroup2's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
I have used Dynamat and Fat Mat. I think the Fat Mat doesn't lay down as well or work as well as the Dynamat. Google 'half price Dynamat' and you should find some deals. I am going to use that and the Dynaliner on my Z28 when I gut it for paint next month- 1/4 inch Dynaliner on the roof and 1/2 inch on the floor. Yes, do the roof- and i wouldnt go cheap on the stuff for the roof- you want it to stay up there!! On the doors: do the outside of the inner skin AND the inside of the outer skin. So both sheets of metal get a layer on the sides closest to you. It will make an ungodly difference to exterior noise, the efficiency of your A/C and your doors will feel like the doors on a Lexus when you close them!!
Lastly, DON'T buy the roller specifically for it- go get one at Lowes for about $2! Same damn thing! Good luck!
Old Dec 28, 2012 | 08:36 AM
donkason's Avatar
I have used Brown Bread for years on two Camaros and my Tahoe. I had 3 JL 12 w3's and a 1000 Watt RMS Soundstream amp. For the IROC I have now I'm using Second Skin paint/brush on to kill the rattles from my system and Ensolite CCF over the rear hump, tranny tunnel, wheel Wells, and doors to keep out the road noise.
Sound dampener does little to kill exhaust/road noise in the car, but keeps the sound from resonating inside the cabin and keeps rattling panels down from a stereo. The CCF or neoprene used above will help keep road and exhaust noise from coming in the cabin. If you have the $ I would do both.
I got 2 gallons of Second Skin and 28sq ft of Ensolite. I'll probably try the Peel and Seal for a few critical spots around the sail panel speakers and rear hatch where my box will sit. I've heard it works well if heated up before applied and it's a fraction of the cost of Dynamat and the like. I only have 1 JL 12W6 going in so I'm using the spray on. If you plan on a big system I would go with conventional roll on dampener. Expect to use 50-75 sq ft if you really want to get the whole thing done and drop some $$$. I'll have $300 wrapped up in all my stuff when it's done.
Edit:
I installed Grace Vycor roof flashing yesterday, a butyl based product about 25 mils thick. People have had issues with roof flashing sticking so I heated mine up with a heat gun and applied it to a clean surface. It will take me 4 rolls of the 4in x 75ft to get my interior mostly covered. I let it cool after installing then heated up the panel with a heat gun and pealed it off. The stuff sticks well when applied correctly.
Old Dec 31, 2012 | 09:41 PM
IROZINCO's Avatar
fatmat on mine. Intalled easy, no smell, works great.
Old Jan 2, 2013 | 06:55 AM
mattyc's Avatar
Car: 1998 grand cherokee, 1988 iroc z
Engine: 350 tpi
Axle/Gears: ???
I used fatmat as well. Three layers of the stuff, my doors sound like a door closing rather than a can being kicked down the street. My exhaust is pretty loud and now the droning noise is gone. I can have a normal conversation. A must do for third gens.
Old Feb 7, 2013 | 10:07 PM
dctrouant1995's Avatar
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Fatmat works great, 140 dollars for 100 square feet and roller. I only did floor plans and doors and still have a roll left http://www.fatmat.com/bulk/fatmat/100.html
Old Feb 11, 2013 | 08:51 AM
jhainer's Avatar
Car: 1986 BBC Iroc
Engine: 454
Transmission: th400
I just did mine this weekend. I used peal and seal. and before you go oh my god why would you use that. I'm not one to just go out and do something i read and read and read about them. I had concerns about smell. melting goo or anything else that might happen that is bad. i happened to find a thread in another forum about useing it. Just did a search on alternative to dynamat. and a hot rod forum showed up. in that thread going back to 2008. most of teh posters were in the southwest and had heats upto 110 degrees in the sun all day with now issues. with melting or smell. and only one guy had issues but it was because he put down bedliner first and it pealed off the bedliner. If you look at the classic dynamat it's the same as the peal and seal. another usefull tid bit the lizard skin stuff is just latex paint mixed with micro ballons interesting to know. but anyways the peal and seal worked fine. i rolled it down just like you would dynamat. I used a heat gun to get it real sticky first. then went back and sealed all the seams with aluninum duct tape just to be sure if it did get gooy it would stay under the tape and not in the carpet. after teh system install when the bass hit the car would rattle door handles everything . now with the peal and seal it doesn't. the system has a much cleaner sound and honestly seems to be louder. the interior isn't all back together yet but it is getting there i also added carpet to the side panels which took most of the time.
Attached Thumbnails For the guys who have done sound deadening...-857223_10200618008155550_1727265577_o.jpg   For the guys who have done sound deadening...-856890_10200618007835542_2005910844_o.jpg   For the guys who have done sound deadening...-843084_10200618010675613_722898025_o.jpg
Old Feb 11, 2013 | 08:59 AM
Twin_Turbo's Avatar
I just used no name brand AluButyl. I have used fat mat and the cheaper no name brand stuff was better than fat mat. I use 2.2mm stuff. The no name had a MUCH tougher alu foil on it, the fat mat broke through a lot easier when rubbing the stuff into beads and dimples with the roller handle. The no name stuff was a lot "tackier" also without heat applied (I do apply heat to shape it)
Old Feb 11, 2013 | 05:24 PM
carlos64030's Avatar
Car: 1991 Trans Am GTA
After reading a lot of reviews online about all the stuff that's available, I went ahead and ordered 36 square feet of Dynamat Xtreme. I only wanna do this once so I want what the pro stereo installers and upholsterers recommend and use.
Old Feb 11, 2013 | 05:38 PM
Sidethumper's Avatar
Car: 87 Pontiac Trans Am
Engine: Lapouttre Racing 350
Transmission: Rebuilt 700r4 Mild shift kit
Axle/Gears: 10 bolt 3.23 posi w/disc brakes
Im still undecided on what I am going to use. But I need to make up my mind soon.
Old Feb 11, 2013 | 07:27 PM
Twin_Turbo's Avatar
Dynamat, a $10 roll of deadener and a $90 name tag
Old Feb 12, 2013 | 08:29 AM
akanitro's Avatar
Car: 1989 GTA, 2004 Z06, 2008 Expedition
Engine: L98, LS3, 5.4L
Transmission: 700R4, MN6, Auto
Axle/Gears: 3.23, 3.42, ?
I used Dynamat for the entire vehicle and it was worth every penny to just do it right the first time and never have to look back. It does add weight to the vehicle and it is very time consuming but when done right, it will make a world of difference. JMO.
Old Feb 12, 2013 | 01:53 PM
Twin_Turbo's Avatar
Mine
Old Feb 12, 2013 | 02:16 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Ive used dynmat in the past. Liked it. but that was when I didnt know any better.
Last car I used a spray on. 2 stage insulator and sound deadner. ( LIZARD SKIN)
http://www.lizardskin.com/sound-control-insulation.html
http://www.lizardskin.com/car-ceramic-insulation.html
Old Feb 12, 2013 | 05:37 PM
Engine: 305 4bbl
Axle/Gears: 3.08
I have 100 sq ft of 50 mil Fatmat and new carpet with mass backing going in this weekend. Thanks for all the recommendations guys. Any tips to make life easier putting it in?
Old Feb 12, 2013 | 05:55 PM
Twin_Turbo's Avatar
heat gun!
Old Feb 14, 2013 | 12:03 AM
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
Originally Posted by Twin_Turbo
Mine
looks good, link to what you used? where ya got it?
Old Feb 14, 2013 | 04:53 AM
Twin_Turbo's Avatar
Ebay Germany LOL Just buy a no name brand of that stuff, it's all pretty much the same and you won't be paying for a name on the foil
Old Feb 14, 2013 | 06:19 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
Second Skin... A while back, tested as the best and also has the highest temp before peeling (all others peeled before it did)...
Pics here...
https://www.thirdgen.org/forums/car-...ide-quiet.html
Old Feb 17, 2013 | 09:08 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
I only use Dynamat Xtreme.
36 sq.ft. did the entire back half of the car.
Pics of the install in my sig link.
Old Feb 17, 2013 | 10:18 PM
toxik IROC's Avatar
Car: 1987 Camaro
Engine: 350 hsr
Transmission: 700R4(blown)
Axle/Gears: 3:73
what about the front half?
MustangBeater20
Oct 29, 2022 09:20 PM
db057
Aug 22, 2015 08:17 PM
midias
Aug 22, 2015 01:42 AM
Street Lethal
Aug 14, 2015 08:25 PM
gwade12
Aug 8, 2015 08:17 AM
