Horn button wire help
Old Dec 27, 2012 | 09:16 PM
bigtizzles's Avatar
Car: 89 Camaro RS (lawn ornament)
Engine: 327 sbc
Transmission: TH350
Axle/Gears: Stock for now
I pulled the old busted steering wheel off my 89 RS camaro to make way for my new grant wheel. It has the ugly square horn steering wheel on it now. I got to looking and there was no wire to connect to the horn? There is a plastic cap that covers the whole end of the steering column around the spline that the wheel bolts to. There is a plastic tube that passes through it that looks like a conduit for a wire. I think I need to buy this http://cgi.ebay.com/ws/eBayISAPI.dll...tchlink:top:en
Am I correct? If so, how do you install it? I hope this isn't a dumb question...
Old Dec 28, 2012 | 08:07 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Horn button wire help
The end with the plastic/spring fits in the tube and a small nub locks it into place (the tube is notched like the one in the first link). The connector end goes to the horn cap/switch. My Grant Signature Series also required a small ground wire to work. The Grant cap accommodates both a hot and ground (second link).
http://www.rickscamaros.com/camaro-h...1969-1975.html
https://www.thirdgen.org/forums/inte...ries-horn.html
Autozone also carries the connector, Dorman 49319.
JamesC
Old Dec 28, 2012 | 09:00 AM
bigtizzles's Avatar
Engine: 327 sbc
Transmission: TH350
Ok, the tube with the notch is still in the car so I guess I have the piece shown in the first link still in the column. I need to confirm that the wire and spring in my ebay link is correct so I can order it. I assume it just clips in the tube. Where did you run the ground wire to because I got a challenger wheel similar to yours and I'll have to do the same thing I assume.
Old Dec 28, 2012 | 10:28 AM
JamesC's Avatar
I'm uncertain if the Challenger Series requires the ground wire. Your instructions should provide all the install info you need.
Good luck with your project.
JamesC
Jorlain
Aug 24, 2022 05:11 PM
5spdcamaro
Aug 28, 2015 02:12 AM
stalkier
Aug 21, 2015 01:54 AM
smooth
Aug 18, 2015 06:34 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
