my led mods
Old Jan 5, 2013 | 12:55 PM
mac86's Avatar
Car: 1987 Camaro Z28
Engine: Carbed 355
Transmission: Borg Warner T56
Axle/Gears: 4th gen 10 bolt 3:73 Richmond gears
my led mods
i have installed blue leds throughout my car. finally finished today. will post pics later today when its dark so i can take em, but what i have is:
blue led strips under dash pad to shine down when headlights are on
blue led strips above where your feet go for when you open up the doors
blue led bulbs replacing any white ones
gauge cluster bulbs replaced with blue led's
blue led shifter plate light
blue led hvac light
Old Jan 5, 2013 | 11:42 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: my led mods
I really wanna see the pics for sure
Old Jan 6, 2013 | 10:39 AM
mac86's Avatar
Engine: Carbed 355
Re: my led mods
ok i was busy last night, i will take some tonight for sure. ill post em around 6
Old Jan 7, 2013 | 01:11 PM
LivinLarge's Avatar
Re: my led mods
Where did you get the led's and what part numbers did you use for the gauges?
Old Jan 7, 2013 | 01:34 PM
6SIX6's Avatar
Car: 89 IROC
Re: my led mods
These are the ones I used on my Autometer gauges
http://www.ebay.ca/itm/2-x-super-Whi...item56513c13b1
Old Jan 7, 2013 | 04:37 PM
mac86's Avatar
Engine: Carbed 355
Re: my led mods
i used 194 led's from http://www.superbrightleds.com/
i used the 5 led's for the gauges and the 6 led for hvac, shifter plate, and floor lights. hopefully i will get pics tonight if i have time
Old Jan 7, 2013 | 05:43 PM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
Re: my led mods
Lets see em!
Old Jan 7, 2013 | 06:16 PM
mac86's Avatar
Engine: Carbed 355
Re: my led mods
looks so much better in person. trust me. looks dull in the photos
Old Jan 9, 2013 | 02:20 PM
mac86's Avatar
Engine: Carbed 355
Re: my led mods
i am soon going to modify and fabricate some extra 194 bulb lights for the trunk area for when the hatch is popped. these will be either an ice white, or super white led. what i am going to do is mount 4 194 led bulbs. one on each seat belt plastic cover, angled inward and down at the carpet, so they illuminate all of the trunk area. then two more mounted on the sail panel plastic angled down toward the rear seat with a switch, so a passenger can use it as a light when it is needed, or if i need it. i also may modify my dome light a bit, or add a panel toward the windshield on the roof for two pivoting lights, one facing the passenger, and one facing the driver, each with a separate button. i may pull this unit off a 1999 tahoe thats in a junkyard, and modify the look, and feel of it to fit my generation of car.
Old Jan 18, 2013 | 10:59 PM
basshead208's Avatar
Car: 86 IROC Z28
Axle/Gears: posi 4 disc 2.73
Re: my led mods
since you like led>>>
Old Jan 18, 2013 | 11:01 PM
Car: 86 IROC Z28
Re: my led mods
and...
Old Jan 19, 2013 | 11:06 AM
6SIX6's Avatar
Car: 89 IROC
Re: my led mods
those door panels are crazy. i like the tail lights as well man. good job
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
