A/C delete
Old Jan 13, 2013 | 07:25 AM
rkg8554's Avatar
Car: 87 Iroc Z 28
Engine: 355/ 600 Holly
Transmission: 700R4 shift kit & vette servo
Axle/Gears: 9 bolt 3;70s
A/C delete
If I am going to install a heat only fan housing do I have to replace all the duct work and controls, or will I be able to use the existing A/C control for just heat and defrost. Thanks
Old Jan 13, 2013 | 09:28 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: A/C delete
You dont need to get rid of the ducts at all. You can look for non ac controls if need be or you can just wire up the wiring you have right now to a AC delete box
Old Jan 14, 2013 | 11:19 AM
rkg8554's Avatar
Car: 87 Iroc Z 28
Re: A/C delete
Thank you !
Old Jan 16, 2013 | 05:21 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: A/C delete
You can use your existing controls, but you can't use a non ac control unless you change the ducts, the non ac ducts are cable controlled, the ac controls use vacuum.
Old Jan 16, 2013 | 07:02 AM
rkg8554's Avatar
Car: 87 Iroc Z 28
Re: A/C delete
Thank you, That is what I was looking for.
jrdturbo
Mar 31, 2016 02:58 PM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
Zell1luk
Sep 29, 2015 10:36 AM
