85 IROC. Converting power doors to manual?
Old Mar 21, 2013 | 09:42 AM
FConn3's Avatar
Car: 1985 Iroc-Z Camaro.
Engine: Forged 383.
Transmission: TH350 with a Hughes 3500 stall.
Axle/Gears: Moser axles and a Richmond 4.10.
I was wondering what all had to be done to convert my power windows to manual? It's an 85 IROC with all power everything. Building a car for the strip and wanting to shed weight and not worry about the vollts and not getting the windows up and down. Just let me know.
Old Mar 21, 2013 | 11:19 PM
toomany's Avatar
Re: 85 IROC. Converting power doors to manual?
Remove your old power window motors and regulators. Install the manual parts. It's a real simple remove and replace deal. It's been a while since I did mine, can't remember if the regulators used all the same mounting holes. Hardest part is wrestling the old parts out.
Old Mar 22, 2013 | 05:25 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
The power regulators use different mounting holes... You'll want to get the manual regulators up against the door shells to mark which holes will be used before you cut the power regulators out.
You will also need to remove the dash pad and undo the upper dash supports to lean the dash back to get the cross-car harness out from under there, followed by the driver's sill plate, kick panel, and seat so you can get the rest of the window harness out.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
