Slow Windows & Bad locks
Old Mar 25, 2013 | 11:14 PM
Z28'83's Avatar
Car: 1983 z28 Crossfire
Engine: V8
Hey guys,
My passenger side door is having trouble unlocking and locking when trying to do it automatically form the drivers side door. anyone have an idea how to fix that? key works fine, and can do it manually from the inside. could it be bad wiring?
Also rolling up and down the windows takes a long time.. what could be causing this?
I have a new battery, not sure if that makes a difference.
Any help works!
Thanx
Old Mar 26, 2013 | 04:29 AM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
Re: Slow Windows & Bad locks
Same here on my '90 T/A. It's just the respective motors being old, especially the window motors.
Speed may vary depending on environmental temperature and the only way to get this fixed is by replacing them.
Regarding the door lock: perhaps you can gain some improvement by WD-40ing rods and moving components over there, but chances are slim.
Old Mar 26, 2013 | 06:28 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by Z28'83
My passenger side door is having trouble unlocking and locking when trying to do it automatically form the drivers side door. anyone have an idea how to fix that? key works fine, and can do it manually from the inside. could it be bad wiring? Also rolling up and down the windows takes a long time..
Years of dirty and grime.
Try cleaning and relubing with white grease. You'll be surprised at how much better both mechanisms will function.
JamesC
Old Mar 26, 2013 | 10:25 AM
fyrebird68's Avatar
Cleaning and lubing the window tracks is always the best place to start, but don't stop there. A lot of lost performance comes from degraded switches, connectors and wiring. If you want to see how well the window REALLY works, hook a car battery directly to your window motor. I bet it will sail up and down!
New switches and sockets work wonders - sometimes pricey tho. Clean the motor sockets and switch sockets with spray electronic cleaner. Look for corroded plug and socket contacts - they should be bright and shiny. Burnish with 1000g sandpaper or dig inside them with a small pointy file. Use some contact dielectric grease.
Check the wires for broken strands at the socket ends, charred insulation, kinks or bare insulation - even where they're hard to get to (no cheating). Pull back the door boots and look in there. You can get switch bypass kits that use higher current wires to run the motors, and the switch runs a relay. (I did this on a Fiero - worked well).
Old Mar 26, 2013 | 01:36 PM
Buggy Disaster's Avatar
Car: 91' Z28. 70' Dune Buggy
Engine: LSX Cam/Full Bolt ons
Axle/Gears: 4.10
I have the same problem and plan on tackling the windows this weekend.
As far as locks, the only thing I had to do was spray some WD-40 into the door lock sylenoid. It works like new now.
Old Mar 26, 2013 | 01:50 PM
IMissMy86TA's Avatar
Car: 1991 Trans Am Vert
Engine: 5.0 TPI
Transmission: T-5 baby
back n the day the windows were pretty slow.. when new from factory...
not sure how slow is slow..
Old Mar 26, 2013 | 01:52 PM
1ACindy's Avatar
it also could be the power door lock actuator has failed.. we sell them here at 1A Auto Parts..
Old Mar 27, 2013 | 08:03 AM
Stauf's Avatar
Car: 91 Z28 Coupe
As far as the windows, all I did was replace the switches. The windows are 5x faster now. For the locks, just use some grease.
Posted from Thirdgen.org App for Android
Old Mar 27, 2013 | 10:35 PM
Z28'83's Avatar
Engine: V8
All sounds good ! i will try all the suggestions ! thanks again
Old Mar 28, 2013 | 04:45 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Um, I have a question regarding the window regulators...
What should be done about a sticky (actually, pretty much STUCK) roller or 2 on the regulator?
I know I need to go through and lube everything inside the doors (door locks are still sticking even after I've lubed them before), and clean up the guts of the motor on the driver's side regulator (new-ish passenger's motor). I also know that a couple of the rollers were sticking. But I don't know what to do about them? I popped at least one off the peg and ran some sandpaper around both the peg and the hole in the roller, but it didn't help much.
Just got the wiring upgrade going and the passenger's window is pretty quick now, but the driver's is S L O W...
Old Mar 29, 2013 | 01:49 PM
fyrebird68's Avatar
Could be the roller is worn out - the hole is so big that the wheel gets cockeyed in the track.
If that's the case try wrapping some teflon tape around the shaft to build out the shaft a little. May work for a while.
Or it could be that the track is twisted or smashed in at some point and the wheel gets hung up. Have a buddy run the window up and down and watch (Also watch your fingers!)
Old Mar 29, 2013 | 01:56 PM
Engine: 2.7L V6
Axle/Gears: 4.41
No, the hole isn't oversized... It's a real pain to get off of the ****. It's almost like the hole is undersized, it's so tight. I suppose I'll try taking it off again and hitting the hole with sandpaper some more.
BTW, if I need another brush/cutout endcap for the motor, do I need to buy a whole replacement motor to get it? IDK how old the brushes are, but I'm 100% sure that the motor is factory to the regulator which was factory to my 87...
Old Mar 29, 2013 | 02:00 PM
Javier87z28's Avatar
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
which reminds me i needs to switch mine out
Old Mar 29, 2013 | 11:39 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
had a new glass installed. when the car was only 4 years old. after they installed it..it was way way to slow.. and before the install.was fast. they had to mess with it.to get it to the same speed as the other side..
was also leaking when car was washed...
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
pfsteichen
Feb 9, 2016 06:59 PM
neekolzun
Aug 24, 2015 04:59 PM
stalkier
Aug 21, 2015 01:54 AM
