Shifter knob help, really simple
Old May 12, 2013 | 03:25 PM
GoalieJohnK's Avatar
Car: 1988 Camaro RS
Engine: 2.8L V6
Transmission: Manual 5 speed
Shifter **** help, really simple
I recently got an 88 RS V6 2.8 Liter. I want to put a new shift **** on it but haven't the slightest clue how to measure it. My real question is will this fit on my Camaro?
Pilot PM146R Red Chrome Manual Shift ****:Amazon:Automotive Pilot PM146R Red Chrome Manual Shift ****:Amazon:Automotive
Thanks.
Old May 14, 2013 | 08:29 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Re: Shifter **** help, really simple
I'd take off the existing one and do measurements. To remove, look at the REAR of the shift ****. There's a small staple-like holder there. Take a very small screwdriver (jewelers is best) and gently pull the staple back until you can grab it with your fingers and pull it out. Then, lift straight up and the **** should slide off. Installation is the reverse.
Old May 14, 2013 | 09:49 PM
Car: 1988 Camaro RS
Engine: 2.8L V6
Thanks! Any idea how to actually measure it? The one I want off
Amazon doesn't hav any measurements listed so I'm not sure if I should assume it's a universal fit.
Old May 15, 2013 | 01:15 AM
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
Most aftermarket ***** come with multiple inserts to match up to the size of your shifter.
Old May 15, 2013 | 10:36 PM
majobis's Avatar
Axle/Gears: G92
I can only speak from my experience with my 87; it is a solid shaft, meaning the **** isn't threaded. Plus, the top of the shaft had a plastic piece protruding which - when applied - allows the shift to be moved out of park. To measure something round like this, an inexpensive option ($1.98) is to go to Home Depot or Lowes and in the hardware aisle (screws, bolts etc.) look for a piece of plastic with holes in it and measurements written all over it. It's probably called a gauge measuring tool. It's good because it also has metric measurements on it for bolts and our cars do have a good amount of metric bolts and screws.
Old May 16, 2013 | 08:23 AM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
your car is a manual, you wont have the staple to remove your ****, just twist like hell, (pro tip: if it seems stuck twist hard to the right(clockwise) then snap it back(counterclockwise) it may take a few tries but it will usually bust the **** loose)
and yes most good shift ***** come with multiple inserts OR give you exact thread measurements
Old May 16, 2013 | 08:35 AM
Caveman305's Avatar
Engine: L03, LB9
according to my searches stock measurements are 16mm x 1.5
Night rider327
Feb 25, 2016 09:50 AM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
