5th Gen Steering Wheel
Old Jun 13, 2013 | 08:35 PM
cw3adkins's Avatar
Car: 87 IROC Z-28
Engine: 5.0L 305 TPI V8
Okay, I've searched around here and did not really see an answer on here yet; so I'll bring it up.
Does anyone on here know of it is feasible to mount a 5th gen steering wheel in a third gen? Are the collar splines different (size/pitch)? If the splines prohibit a 'plug and play' mount, you guys think that we can by-pass this issue with a quick disconnect unit (here)?
Just wondering, I do like the look of the new wheel and the idea of wheel mounted radio controls (could care less about the airbag).
Old Jun 14, 2013 | 09:17 AM
Cadaver_Puncher's Avatar
Car: 92 Camaro rs ( mostly stock for now
Engine: 3.1 v6
Transmission: 700r4 with a b&m megashifter.
Axle/Gears: whatever came stock. wanna posi tho
Re: 5th Gen Steering Wheel
Flaming river has a similar wheel called the waterfall. Plus with the flaming river wheel, you can choose the grip color.
Old Jun 14, 2013 | 12:19 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
I think it would look really weird and out of place in a 3rd gen. The hub is about twice the size of our cars since the steering columns are so much larger in the new ones.
Old Jun 14, 2013 | 12:33 PM
90 Z28SS's Avatar
It won't work at all sorry to say. The 5th gen column has a large center bolt not a splined shaft, therefore there is no splined hole in the steering wheel like prior GM wheels. If your knowledgeable with aluminum tig welding and have a plasma cutter it could happen.
Old Jun 14, 2013 | 02:50 PM
cw3adkins's Avatar
Car: 87 IROC Z-28
Humm, well in that case, I'll have to see if I can cannibalize an entire 5th gen column and steering wheel assembly to work in a third gen.
Frozer!!!
Jan 19, 2024 04:55 PM
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
