Seat belt install, how to get this thru that?
Old Jun 24, 2013 | 08:01 PM
gearheadotaku's Avatar
Car: '91 Firebird
Engine: 305 TBI w/LT1 cam
Transmission: T5 swapped in
Axle/Gears: 9 bolt 3.27 w/discs
Replacing the left front seat belt in my '91 Firebird. How do you run the belt thru the loop that's bolted to the headrest? It doesn't split open like the earlier cars, and neither of the reels will pass thru it.
Whats the simple answer to my dumb question?
Old Jun 24, 2013 | 08:04 PM
Twin_Turbo's Avatar
Re: Seat belt install, how to get this thru that?
You have to cut the loops to be able to get the belt back in.
Old Jun 25, 2013 | 08:38 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
What he said. These are how the 4th gen loops look.
Old Jun 25, 2013 | 08:42 AM
Twin_Turbo's Avatar
I would cut them between the bolts that way you will not see the cut. I also angle the cut so the 2 pieces sort of itnerlock for a tighter mounting
Old Jun 25, 2013 | 03:48 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Those are for a 4th gen Convertible...all coupes still had the closed design. Difference is, you don't have to cut anything to install them in a 4th gen. Just pull out the piece that mounts to the headliner, and it slides right over the belt.
Old Jun 27, 2013 | 05:44 PM
fozzi58's Avatar
Car: 89 Formula
You don't have one like this?
http://www.ebay.com/itm/82-92-Camaro...-/321149900991
Odd cause most of 3rd Gens had the same one except maybe my 82 TA. But my 86 & 87 Firebirds had them like that.
1992 Trans Am
May 10, 2023 07:19 PM
MORREALE5
Sep 13, 2015 09:16 PM
Navy8125
Aug 22, 2015 07:13 PM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
scottmoyer
Aug 9, 2015 10:18 PM
