rear split seat?
Old Aug 3, 2013 | 07:30 AM
deadman's Avatar
Car: 89 camaro
Transmission: 700r4 w/ shift kit
Axle/Gears: stockers
rear split seat?
I have a fold down 4th gen rear seat in my car now but I found a split rear seat in better shape and im wondering if its a direct bolt in? right now I have all 4th gen seat but I found a full set of 3rd gen black seats that I like better only problem is ive never had a rear split seat in my car .
Old Aug 3, 2013 | 08:01 AM
rdhanded2's Avatar
Top Answer: 1
Car: 91 TA / 91 Formula
Re: rear split seat?
The center on split rears have a tab they lock onto. You need to weld that into your car for them to work. Also, make sure you measure the exact spot to weld them onto or the seats won't fit right.
Old Aug 4, 2013 | 07:02 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
my 89 came with a split rear seat.your car should already have the inner mounts sticking through the carpet unless someone cut them off like i did..
Old Aug 4, 2013 | 08:05 PM
rdhanded2's Avatar
Top Answer: 1
It only has the mounts if it was a split seat car from factory or someone added them.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
MORREALE5
Sep 13, 2015 09:16 PM
