Interior out - what should I do now?
Old Aug 26, 2013 | 02:00 PM
72SSboy's Avatar
Car: 1988 IROC-Z
hey there -- I have pulled my interior out.. INCLUDING the dash.. what a bear.
https://www.thirdgen.org/forums/inte...lots-pics.html
there's the thread. For the experts here.. what should I be sure to do while it's out? Should I pull the carpet? The car is absolutely rust free.. should I line-x it? Should I dynamat it? Should I replace the carpet? Any and all advice is more than welcomed! Thank you!
j
Old Aug 26, 2013 | 03:12 PM
rdhanded2's Avatar
Top Answer: 1
Car: 91 TA / 91 Formula
Re: Interior out - what should I do now?
When I had mine out, even though it was a rust free car as well, I wire wheeled and used por-15 on the floor pans. Then I used dynomat over it all. Not for radio, but noise and heat. Made a big difference.
Old Aug 26, 2013 | 03:15 PM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
If you haven't pulled the carpet then you don't know it's rust free yet.
I would pull the carpet and probably replace it, nothing freshens up an interior like new carpet. You may find some rust starting, so get rid of that first. If it really is rust free, leave it alone. New carpet can be ordered with the padding, so not necessary to add more insulation unless the original was not sufficient for you. If you feel like it, adding some dynamat or similar over the tunnel can cut down noise and heat a lot.
Take the opportunity to really explore inside the b pillars, amazing what you might find in there. I've found all kinds of tools,cans, bolts, mouse nests, snakes, etc.
Old Aug 27, 2013 | 12:03 PM
1986 305 RS's Avatar
Car: 1986 Sport Coupe
Engine: 305 V-8 670 cfm Holley st avenger
Axle/Gears: 13-42
Im in the same boat minus the dash. I agree with pulling the carpet I thought mine was rust free too and there was light surface rust on the passenger floor board but if I had not found it it could have become a issue 5 to 10 years from now. Darn this thread reminded me about my t-top area ty its rusty and needs to be addressed before it gets back on the road.
RyanJB
May 7, 2016 06:23 PM
codeysabatini
Sep 20, 2015 11:36 AM
MORREALE5
Sep 13, 2015 09:01 PM
