Seat Belt Issues
Old Sep 6, 2013 | 08:42 AM
z28v8's Avatar
Car: 1987 IROC-Z
Seat Belt Issues
I've searched but couldn't find the answer here... so hopefully someone can answer and/or point me in the right direction...
Every other car I've had, the seatbelts will lock when I give it a good tug. The seatbelts on my 87 don't want to lock to matter how hard I try. I checked out the seatbelts in 7 (yes, seven) ThirdGens at the junkyard yesterday and they all had the same symptoms (the ones that actually retracted, anyway).
I'm pretty sure it's not my weakly arms and verified by checking the seatbelts in non-Camaro cars. So is this normal? It just seems hard to believe that all 4 seatbelts in my car AND all the seatbelts in the junkyard cars that I checked would be 'broken' in the same manner.
Cheers
Jeff ~
Old Sep 6, 2013 | 08:57 AM
OdieTurbo's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 3.4L V6
Transmission: T5 (NWC)
Axle/Gears: 3.42 Stock axle
Re: Seat Belt Issues
My '87 is the same way. I think it's on purpose and they only lock in an accident or heavy G forces. A lot of folks apparently swap in 4thgen seatbelts since they are at least fixed at the lower point.
Old Sep 6, 2013 | 07:56 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
did you try a panic stop?
Old Sep 9, 2013 | 07:58 AM
Jonesyfxr's Avatar
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
There's a GM rebuild kit for the lathes. I just bought it off EBay. The part number is 14097930.
Old Sep 9, 2013 | 08:45 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
The retractors on the roof have inertial sensors in them. They don't lock due to rapid pull like others. If your car is parked on a steep hill, they sometimes won't release. Its a pretty poor system. You can test them when they are removed from the car by tilting the retractor back and forth.
Old Sep 9, 2013 | 01:55 PM
Jonesyfxr's Avatar
Oh, I thought you meant the actual latch....DUH!
1992 Trans Am
May 10, 2023 07:19 PM
MORREALE5
Sep 13, 2015 09:16 PM
Navy8125
Aug 22, 2015 07:13 PM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
scottmoyer
Aug 9, 2015 10:18 PM
