Paint removal
Old Sep 26, 2013 | 05:26 PM
Bruce91RS's Avatar
Paint removal
What's the best way to remove spray paint from my interior pieces. Prior owner sprayed some parts silver.
Old Sep 27, 2013 | 06:33 AM
Bruce91RS's Avatar
Re: Paint removal
Really? Not even a "use sandpaper "? I want to remove the paint without hurting the plastic. Any product recommendations?
Old Sep 27, 2013 | 07:11 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: Paint removal
Depends what they used on it. You can try really hot water, if the paint didn't bond well that will take it off. If it did bond well, I think the only solution is sanding or painting over.
Many of the plastics are easy to find used, might be easier to just replace them.
Old Sep 27, 2013 | 09:09 AM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
Re: Paint removal
wipe with nail polish remover?
soak in gasoline?
paint thinner?
"use sandpaper?"
not sure what kind of ill effect it will have on the plastic but it will take the paint off
and stealtht/a is right, depending on the pieces you can get them cheap in good condition
Old Sep 27, 2013 | 12:00 PM
92rssbCamaro's Avatar
Re: Paint removal
This may sound strange but, soak them in Brake Fluid; it will cause the paint to peel off without hurting the plastic. Depending on how well the paint has adhered to the plastic they may have to soak for some time, but the paint will come off.
Old Sep 28, 2013 | 05:37 AM
Bruce91RS's Avatar
Re: Paint removal
Brake fluid was my idea too. I was looking for a second opinion on that. Wasn't sure if it would hurt plastic during soaking. Thanks.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
Wife'sCar
Aug 22, 2015 01:46 PM
3rdgenparts
Aug 8, 2015 07:09 PM
