Door screws/washers
Old Sep 30, 2013 | 04:18 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Door screws/washers
Hey all,
I'm looking for the screws that hold the window felt to the plastic trim piece (window sweeps?) on the door. I have a couple on the drivers side but near the rear of the door it sort of falls down inside the door because I don't have anything holding it in place.
I also need the metal rings and screw parts that hold the plastic trim to the door panel itself and the white push pieces that hold the door panel to the door itself. My passenger door panel is nearly falling down and I want to replace the door panels but I need these parts to do it. Thanks!
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
kkirch15
Sep 30, 2015 04:44 PM
