guide on fixing a door handle and heater problem
Old Nov 30, 2013 | 02:52 PM
91camarox's Avatar
Car: 91 camaro rs
Engine: 305 tbi
hi im looking for a guide to fixing my driver side inside door handle beacuse it will not open. im also looking for a guide to fixing my heater switch it will only work on defrost and will not blow in any other hole.
thanks in advance
Old Nov 30, 2013 | 03:16 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: guide on fixing a door handle and heater problem
Look for one of these on E-bay or the classifieds
http://www.helminc.com/helm/Result.a...ected%5Fmedia=
Old Dec 5, 2013 | 11:54 AM
a62belair's Avatar
Car: 88 Firebird, 87 Formula
Engine: 2.8, 5.0
Transmission: both 700R4
Axle/Gears: 3.42,3.45
Make sure you have vacuum to the dash control. Defrost is the default setting.
Good luck!
Old Dec 31, 2013 | 02:38 PM
Fbdy-Z28-92's Avatar
For your heater switch first check all of the vacuum lines I. The engine compartment. If that doesn't fix it check out this:
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
86IROC112
Apr 9, 2016 10:20 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
