Tabs breaking on trim parts
Old Dec 3, 2013 | 08:26 AM
pontiacdog's Avatar
Car: '86 Trans Am
I have a problem with all the plastic trim parts etc that are held in place by small tabs.
Yup, I tend to break at least one tab every time I remove the part.
Can the tabs be repaired or replaced in any way?
Most of the time you can't see the damage if the part fits tightly..
But the seatbelt trim piece on the headliner won't stay in place and a plastic scoop on the body of the car (near the front tire) flaps around.
Old Dec 3, 2013 | 08:44 AM
Lakerman62's Avatar
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
Re: Tabs breaking on trim parts
i have found some of the needed trim parts @ Hawksthirdgen,and at local junk yards, the auto parts stores rarely have the exact part, but sometimes I get lucky. when I installed an overhead console, I took the headliner out re-installed everything & now my seat belt trim stays intact. I would advise to get a helper to hold the headliner as I did it myself & in would have been easier to have help with holding it up while I worked on it. But, it can be done solo. gather up your needed parts & then set aside time to do it. have a few extra tabs ready in case you break them while doing install. The a-pillar plastic trim & upper window plastic trim/headliner tabs have been a pain for me. Take your time, good luck
Old Dec 4, 2013 | 07:25 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Tabs can be glued back on with Plastic weld.
If you are missing the tabs, they can be recreated with plastic weld or repair compounds for bumpers, such as SEM plastic "problem solver"
Old Dec 4, 2013 | 07:23 PM
whtltng89's Avatar
Car: 1989 TA
Engine: 5.0L
I would just get some new ones from Hawks,junk yard ones will be brittle and probably break when you pull them. Total waste of time lol Ive glued them before and rebroke them.
Old Dec 5, 2013 | 07:24 AM
stealtht/a's Avatar
New ones? They only make a couple of new parts. Used is all you are going to get for most interior parts.
Old Dec 6, 2013 | 12:37 PM
pontiacdog's Avatar
Car: '86 Trans Am
I've found this to be true.
Anyway, I'll try gluing the tabs back first since new interior parts are very expensive.. I mean, I don't want to order a 40 dollar piece of plastic every time I take it off and break one of the tabs .
Unfortunately I didn't think of gluing when I just threw the broken piece away...
Old Dec 6, 2013 | 04:37 PM
whtltng89's Avatar
Car: 1989 TA
Engine: 5.0L
Hawks has the particular clips you need,$1.49 ea, There are more clips,fasteners,etc available out there than you realize,just because its a 2nd gen firebird,dosent mean a 2013 honda clip wont interchange.Ive got nothing against glue,but if there is a way to replace it with "New",thats the way I will do it.Somewhere Ive got a web site or two that has about ANY automotive fastener that was ever made.I will see if I can find one and will post it.
1992 Trans Am
May 10, 2023 07:19 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
