4th gen interior parts query
hi all, I couldn't find any info on this so hoping someone can help.
I am in Australia and cant find what I need locally.
basically redoing the interior in my third gen and need to customize a fair bit.
I am in the process of fitting up a GTO dash and need to modernize the door panels to suit.
I want to use the 4th gen firebird door panels as a base and have been looking thru the online dismantlers but they seem pretty pricey @ $250 a pair.
1. Is this a standard price?
2. Who sells firebird parts at good prices? (they don't need to ship internationally)
also trying to find out if the 4th gen interior door sills fit into a third gen?
i haven't seen any yet, but hoping they are more modern and flexible than the third gen ones.
Vince
Vince
Car: 1992 Jade Green---Trans Am Converti
Re: 4th gen interior parts query
Best bet is to cut the third-gen sill, then use the 4th gen seal and kick-panel piece.
$250 for a non-cracked set of 4th gen panels isn't bad. If they're all ready cracked (which is fine if you are using them as a base, too much). Put a wanted add on ls1tech.com and you should be able to find some cracked ones.
Kevin D.
Kevin D.
Kevin D.
Kevin D.
Nothing from car pics I posted are for sale though. Looks like it is being parted but it was a z28 donor car I bought for motor and stuff, then put a 3.8 in it and gave to my girlfriend.
hi Kevin, yes a cracked set would be the way to go for me.
not sure what you mean by ' cut the third-gen sill, then use the 4th gen seal and kick-panel piece'
I cant view the picture you are posting.
please email if you can.
genclubby@hotmail.com
jeff, I will check out pickapart.
Vince
Vince
Vince
Vince
The 4th gen sill is also doesn't use screws to hold it in place it uses metal like wedge clips, plus it's overall shape would make it quite difficult to put on a 3rd gen.
1992 Trans Am
Aug 8, 2015 08:16 PM
