manual trunk latch
Old Dec 31, 2013 | 10:58 PM
Nighthawkf-117's Avatar
Car: 91' Camaro RS
Engine: 305 TBI V8
Transmission: 700/R4
Axle/Gears: Stock
manual trunk latch
Hey guys, I've screwed with my electric pull down quite a bit and just want to go the manual route. Can I fab up an appropriate sized adapter plate, and buy a regular manual style trunk latch? Any cars that have manual trunk latches that are close to the Third Gens?
Old Jan 1, 2014 | 03:55 PM
Buggy Disaster's Avatar
Car: 91' Z28. 70' Dune Buggy
Engine: LSX Cam/Full Bolt ons
Axle/Gears: 4.10
Re: manual trunk latch
If you look at the entire electric hatch pull down assembly you will see two "plates". One plate is bolted to the body of the car by 3 screws that allow you to adjust the assembly. The other plate is attached to the plastic guides and moves up and down when the electric motor goes up and down.
You can line these two plates up together in the position that they sit when the hatch is closed. Then drill a hole and bolt them together. This way the assembly is now in a fixed position, allowing you to manually close the trunk like any other car.
Old Jan 3, 2014 | 08:14 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Here's a pic of the manual "POP' hatch latch set-up used from 82-85,.... It could be bolted, riveted or welded to the body to convert to the early style.
Old Jan 3, 2014 | 09:12 PM
Car: 91' Camaro RS
Engine: 305 TBI V8
Axle/Gears: Stock
Did this and it worked great! Thanks for the easy solution.
Falcon50
Aug 22, 2020 03:26 PM
Fireslash
Apr 11, 2016 06:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
