Leather Covered Dash Pad & Console Lid
Old Jan 31, 2014 | 04:53 PM
  #51
thatoneguy5x's Avatar
Car: camaro
Engine: 3.1
Transmission: auto
Re: Leather Covered Dash Pad
Originally Posted by 84 1LE
Thats spot putty, most of it was sanded away.I wouldnt use it again though.Was fine in the center, crumbled too easy near the edges.
thanks for the response i will probably find a different product but great job!
Old Jan 31, 2014 | 06:18 PM
  #52
86WS6's Avatar
From: Great Smoky Mountains, Bryson City North Carolina
Car: 86WS6 30K and 82WS7 24K
Engine: 86:305 TPI, 82: 305 LG4
Transmission: 86:700R4, 82: T200C
Axle/Gears: 86:3:27 9 bolt, 82: 3:23 10 bolt
Awesome Job!
Old Jan 31, 2014 | 07:17 PM
  #53
visitor's Avatar
Car: genesis, equus, f250, camaro, other
Engine: 5.7
Transmission: t5
looks nice! When I worked at the upholstery shop we did a few dashes. Heres a 58 vette we did the entire interior in, including wrapping the dash..
Old Feb 1, 2014 | 10:30 AM
  #54
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Originally Posted by ghettocruiser
You wouldnt use what again..? The expandable foam or the spot putty?
And for either answer, what would you use in its place?
Im trying to figure out how you sewed up the corners. I have sewn a few things lately...like shift and e-brake boots. But I cant wrap my head around how you did that.
J.
The spot putty, or anything that dries hard.The foam is perfect density.Feels like a gel pad when cured, wont dent, is easy to cut/shape/sand.In fact i'm using it for a console lid im currently re-doing to match the console/wheel/seats.
By not glueing the corners i was ablle to pull the leather back & sew from behind.Afterwards i use a little glue, but mostly i stretched the leather back over the corner.Then finished stitching the underside, but from the outside.Most of that will be covered by the dash & only about 1" will be visible, if you look underneath.
Old Feb 1, 2014 | 12:31 PM
  #55
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Just an all around nice damn job.
Old Feb 2, 2014 | 12:25 AM
  #56
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Thanks, almost done w/ this.
Figured i'd do the console lid.Its a JY piece w/ many cracks.Repaired & installed steel rod to reinforce it.
Sealed it Oatey ABS cement.
Rebuilt foam.
Old Feb 4, 2014 | 11:56 PM
  #57
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Re: Leather Covered Dash Pad & Console Lid
Done.I'll get the dash in tommorow.
Old Feb 8, 2014 | 09:31 PM
  #58
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
And the dash.
Old Feb 8, 2014 | 09:47 PM
  #59
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
And the dash.
In Olympic fashion....
Old Feb 8, 2014 | 10:09 PM
  #60
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Great job 84 1 LE!!
IROCgiraffe - Lol!!!
Old Feb 10, 2014 | 09:44 AM
  #61
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Thanks guys.
Old Feb 11, 2014 | 10:48 AM
  #62
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
That looks amazing... Seriously... If it was something you could easily reproduce at home, and get shipping at a reasonable cost, you'd have yourself a pretty decent business. I have never seen a dash pad refinished like this and it looking so nice in the end.
Great work! Im DEF keeping my old cracked dash from my 87 now! I might try to find material that is more consistent in finish rather than the unique characteristics of the leather finish (so probably synthetic), but Im DEF following your example on how to make it look awesome!
Justin
Old Feb 11, 2014 | 06:45 PM
  #63
Van Nuys born's Avatar
Car: 4/89 IROC Z28 G92 -
Engine: LB9 TPI
Axle/Gears: 3.45
Look's Great !
Old Feb 12, 2014 | 11:12 AM
  #64
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Justin
Cost of the leather, plus the shipping, would be too high.I lucked out when I scored the leather for this.It's twice as big as the dash at least & I paid peanuts for it.Just for the dash alone real leather will cost about two bills.Just not feaseable.
This was my first try at this & I figured it out along the way.Shouldn't be too difficult for others.
Thanks all for the compliments.
Old Mar 17, 2014 | 01:26 PM
  #65
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
84 1LE - Another great thread by you on modding a 3rd gen. This is gonna be a project for sure in the summer as I have quite a few wrecked dash pads I was saving to do something with. Thanks for the write up and the idea to fix them
Old Mar 18, 2014 | 11:14 AM
  #66
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Thanks.Glad to help & motivate.
Old Apr 18, 2014 | 12:37 PM
  #67
SheckyZ28's Avatar
Looks damn nice
Old Apr 24, 2014 | 11:04 AM
  #68
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Thanks.
Old Apr 29, 2014 | 02:21 PM
  #69
georgiaslim45's Avatar
Car: 1986 Camaro Z28
Looks great
Old Apr 29, 2014 | 05:50 PM
  #70
IrocdreamZ's Avatar
Great job, i had plans of doin this after finding a huge roll of nogahide in my dads garage... Glad to see some pics of what u did as a reference... New dash pad and headliner comin up!!!
Old Apr 29, 2014 | 08:29 PM
  #71
IrocdreamZ's Avatar
Old Apr 29, 2014 | 08:42 PM
  #72
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
wow, I have an extra (cracked) dash pad. I may have to see what I can do about trying this
Old Apr 29, 2014 | 10:10 PM
  #73
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
It sucks that we can't do this to the Camaro pad because of the speaker grille are not the same....
Old Apr 29, 2014 | 10:15 PM
  #74
58mark's Avatar
that was a camaro dash pad
Old Apr 29, 2014 | 10:25 PM
  #75
90camaro355rs's Avatar
Car: 72 nova/ 90 camaro rs,04 suburban
Engine: blown 327/ 355/306/355/5.3
Transmission: muncie 4 speed/T5/powerglide,4l80e
Axle/Gears: 342/411/456/ moser axles
man that looks great!
Old Apr 30, 2014 | 09:09 PM
  #76
Duane's 91 Z/28's Avatar
Car: 1991 red Z/28
Transmission: T5 swap
I started doing mine. Got the old hard cracked vinyl peeled off and got some foam sprayed on and sanded about 1/4 of it smooth. There are quite a few little air bubbles up to 1/4 inch. Should I try to fill them or will they be ok?
Old May 1, 2014 | 12:10 AM
  #77
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
As mark said, that is a camaro pad.
I would try to fill them in.Especially the larger ones.Anything bigger than about 3/16.If the leather or material used is fairly thick the smaller ones wont show thru
One trick i learned while doing this is to gently press the nozzle so less air mixes with the foam.Flows very slow, but result is denser foam/smaller holes.
Old May 1, 2014 | 08:58 PM
  #78
Car: 1991 red Z/28
One trick i learned while doing this is too slowly press the nozzle so the foam comes out real slow.This causes less air to escape.Resulting in denser foam & smaller holes.
Ok thanks I will give that a try once I am done sanding the whole dash. I just have to be patient with it.
Old May 2, 2014 | 03:59 PM
  #79
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Dude... wow. Awesome work!! Was imagining mine in black suede with blue stitch... maybe someday :P
Old May 3, 2014 | 07:44 PM
  #80
Car: 1991 red Z/28
What kind of glue did you use on your dash?
My bad I just saw your post.
Old May 11, 2014 | 10:50 AM
  #81
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
That glue works really good.Make sure you have the material positioned correctly before layig it down.
Old May 11, 2014 | 07:51 PM
  #82
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
GREAT JOB so far.
Plan on covering anything else?
Old May 11, 2014 | 08:27 PM
  #83
fatalicshock's Avatar
Car: 87 Trans Am
where did you get the leather from
Old May 12, 2014 | 03:37 PM
  #84
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
EBay.
Originally Posted by The Project
GREAT JOB so far.
Dr panels, maybe center console.
Old May 20, 2014 | 08:22 AM
  #85
Amaro83's Avatar
Car: !983 Z28
Engine: 355
Transmission: rebuilt 700R4
Axle/Gears: possi rear end
WOW!!!!! I am impressed!! That looks great!! I havee been looking at getting a new pad, but you have givin me inspiration as well!!!! I am very excited about starting mine!! Thank you for all the posts!! But how did you sew the corner pieces? That looks real difficult!!
Old May 20, 2014 | 09:03 PM
  #86
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Post 54.
Old May 22, 2014 | 06:28 AM
  #87
Amaro83's Avatar
Car: !983 Z28
Engine: 355
Awesome. Thanks!! I think I'm gonna give it a shot!!! Cheaper than buyin a new one!! Plus, I like the idea of having the original one in!! Now, did you use any special kind of needle or thread to do your sewing? Is there anything that you wish you woulda done different? I think this may be next months project!!
Old May 24, 2014 | 06:07 PM
  #88
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Maybe the speaker grills.
I used a curved needle, thicker than normal & heavy guage thread.
Old May 25, 2014 | 12:27 AM
  #89
Amaro83's Avatar
Car: !983 Z28
Engine: 355
Ok. Thanks. How do you think you woulda done the speaker grills different? Its kinda tough with our cars!!
Old May 25, 2014 | 01:15 PM
  #90
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Not sure, but i know they could better.Thankfully, they pop out.
Old Apr 17, 2015 | 07:05 AM
  #91
antman89iroc's Avatar
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Did you consider filling them in and just covering the speaker opening up with material? I don't have speakers in my dash anyway so I thought filling them in would work well and be very clean.
Old Apr 17, 2015 | 02:41 PM
  #92
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Not an option, since I have speakers there.It would muffle the sound too much
Old Apr 17, 2015 | 04:23 PM
  #93
Car: 89 IROC
Engine: 6.8 HSR N2O
No doubt but don't you think it would make mine a bit easier to do?
Old Apr 17, 2015 | 04:46 PM
  #94
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
Looks great! Also, good for you for actually trying something on your own. Hopefully it lasts you a long time.
I tried searching for a post one member made but couldn't find it. This guy actually had his recovered by a shop and had the lip stitches in white to match his interior. It looked fantastic. Wish I could find it.
Old Apr 17, 2015 | 10:14 PM
  #95
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
It be just a tad easier, the center vents are your big hurdle.Speakers are flat & easy to cover.
Old Apr 18, 2015 | 12:54 AM
  #96
87350IROC's Avatar
Car: 87' IROC
Could be me. I just converted my center console from gray to black and finally get to see how the shift boot and arm rest will look together with the center console. But 84 1LE gets super pimp points for doing all the work himself. It looks great. I don't have the skills to do stitching myself. Mine was done by the folks who did my seats.
I still need to convert the console vents to black.
Old Apr 18, 2015 | 07:57 AM
  #97
Car: 1991 Firebird
Engine: 3.1L V6
No, I saw it probably over a year ago.
Looks as though you are doing the same design though. Love it! Very nice 87350IROC!
Old Apr 18, 2015 | 09:10 AM
  #98
87350IROC's Avatar
Car: 87' IROC
I have actually had that since 2012. Camaro progress has been slow for me lately.
Old Dec 16, 2015 | 06:59 PM
  #99
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
any updates ?
Old Dec 16, 2015 | 08:58 PM
  #100
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Who for?
